Results 14 to 22 of 22
Thread: Ice-O-Matic ice machine
10-07-2012, 08:32 PM #14[Avatar photo from a Florida training accident. Everyone walked away.]
2 Tim 3:16-17
RSES Certificate Member
AOP Forum Rules:
10-07-2012, 10:17 PM #15
10-08-2012, 02:00 PM #16
- Feb 2012
- Savannah, NY
- 67
Pressure during freeze cycle is 22 and 210. During harvest it is 65 and 130. It went through three whole cycles before it dropped ice and it only dropped on the left side. Also only dropped a half evap. coil worth, the right side did nothing. Also only forming ice on bottom of coil. Bottom tube going into coil is frosting during freeze cycle, top tube is not.
10-14-2012, 06:44 PM #17
- May 2012
- 17
might be a bda breaker i usually shoot it w my temp gun and feel if its hot also make sure all the wires are tight and the lugs arent loose
10-16-2012, 09:32 AM #18
- Feb 2012
- Savannah, NY
- 67
I added a couple ounces of refrigerant and has been running great. No tripped breaker and making ice like crazy.
10-17-2012, 02:16 PM #19
- Feb 2012
- Savannah, NY
- 67
Spoke too soon. Not producing ice again. The breaker didn't trip but its not making ice. Any ideas here? Going to check it in the morning but was wondering if anyone had any advice as to what to look for if they have been down this road. Thanks
10-18-2012, 12:38 AM #20
10-18-2012, 07:56 AM #21
- Jan 2005
- texas
- 110
Find the leak and fix it,make sure all the refrigerant is recovered then weigh in the full nameplate charge. Your compressor is shortcycling on low charge untill the breaker trips.If you had a single phase unit you would blowing start components. Like some one said post model & serial #s (omit last four digits in serial #)
10-18-2012, 11:10 AM #22
- Feb 2012
- Savannah, NY
- 67
MOD# ICE1406FW2
SER# C420-00298-Z
