    Sep 2012
    2-Stage Condensing Unit Questions
    A couple of quick questions on 2-stage AC systems...
    1) I've been looking at Trane's 2.5 ton single-stage units. Trane's two-stage units come in 2-ton and 3 ton, no 2.5 ton. In this case, should I go up or down in size?
    2) When a 2-stage system is running on 1st stage, what percentage of its full capacity is typically being used?
    Thanks!
    D.
    1. What is the heat gain for the space? Hopefully someone did one!
    2. Depends upon the match. I've seen them where low was as much as 81% of total capacity. Most with the unloading scroll are in the 75% range.
    A Trane 3 ton 16i in first stage is between 70 and 80% of full capacity. A Trane 3 ton 20i in first stage is roughly 50% of full capacity.
