Results 1 to 12 of 12
    May 2005
    why are txv solder connections so short??
    i just soldered a txv into a new evaporator, theres a ton of room in the evaporator
    but the txv seem to have as short a connection as they can make...
    May 2010
    Oxford, UK
    I mostly fit danfoss valves, often find it easier to put some stubs on the valve before fitting where access isn't good in its correct position.
    May 2005
    i installed a danfoss the other day, i went to set the superheat and was suprised the adjustment was on the side...do u use regular silver solder on those??
    Oct 2011
    between here and over there
    I find using flux and a little 15% does wonders on those. I don't like how they are so close to to the body makes me nervous installing them. doing all that work just to find that you burned it up installing it..
    NH
    Quote Originally Posted by primmers View Post
    LOL.. Yep don't ever try to unscrew the bottom to adjust it you'll be in for a surprise.
    As far as short connections on the valves, I'm guess its a cost thing. I just try to burn it in real quick with little 1/2" or so strip of wet rag wrapped around it. With the danfoss valves you heat the pipe mostly then just touch the fitting when the pipe is hot enough.
    I get more pissed at the short connections on filter driers then txvs. Got to love the smell of burning paint.
    NH
    May 2010
    Oxford, UK
    These are the sort of valves we get here, (this is on a bulk milk cooler)
    http://www.youtube.com/watch?v=V5C4LqDADNA
    I wrap the valve in a wet rag and have a pepper pot burner on the oxy acetylene torch. I use 15% silver rods and no flux as the rods are self fluxing on copper and copper plated fitting.
    Southeastern Pa
    I'd want to see that Danfoss valve in use after that. Not just pipes in a lab.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Jul 2012
    Western KY
    The more we burn up the more they sell us.
    Jun 2012
    changed a lot of danfosses on Manitowoc ice machines, put a wet rag on them and they're fine, those are all Danfoss TUC series valves
    timebuilder Have you ever brazed in a Danfoss like they show? The Stainless is so thin I would hold the valve by the head while you braze it. You could grab the body shortly after. They show much more heat than is needed IMO.
    Jul 2011
    Lehigh Valley, PA
    Quote Originally Posted by monkeyspanners View Post
    That's long stem cryogenic valve used a cryo system. That brand valve is made in England. I installed a bunch of them on liquid cryo stations.
