    Noticed that the secondary drain from the pan under the air handler was dripping yesterday. The main line is clogged. What can I do to get it unclogged? I tried bleach, didn't work. I tried to fashion a hose hooked up to my leaf blower, didn't work. What else can I do? Thanks for the help.
    Rapid City, SD
    Where does this line go to (the main one). If it's easy to get access to the end try hooking a shop vac up to it.
    Shouldn't be real hard to unclog, but there's always a chance it'll be a pain.
    VETO PRO PAC, The Official Tool Bag of HVAC-Talk.com
    Testo... you guys rule!
    It comes out of the air handler and then makes a "t" for the clean out and then makes a ninety goes about 3 feet and then makes another ninety down. From there I have no idea where it goes.
    Naples, Fla.
    Do not use bleach - there's a reason it comes in a plastic jug -- it's caustic.
    You must find the termination point for the drain, sometimes a shop vac works, professionals use a sluge sucker powered by nitrogen or C02.
    I'd suggest you seek a competent HVAC contractor for seasonal maintenance. If the drain line is that bad, the pan will be a slimmer.
