Results 1 to 9 of 9
    Oct 2012
    Methuen, MA
    Confused Existing A/C Piping For New R-410A Refrigerant
    I'm getting ready to have my condenser and coil replaced with a brand new system that uses R-410A refrigerant. One HVAC tech tells me that the existing pressure piping can continue to be utilized with the new refrigerant R-410A because the old R-22 can be simply blown out of the existing copper line. I'm seeing different opinions on-line HERE.
    Should I have all pressure lines replaced?
    Jun 2006
    Richmond, VA
    I don't see any different opinions in the article????
    If the lines can be replaced then replace them. It's not a requirement, other than blowing the existing lines out with nitrogen.
    I wish I had a $1.00 for every response I deleted.....
    "Decidedly Superior in a twisted pathetic way".....
    Oct 2012
    Methuen, MA
    beshvc, This article (at the end) clearly states to replace this line...period. I'm simply attempting to get professional HVAC tech's to chime in with their opinions.
    Jun 2006
    Richmond, VA
    Quote Originally Posted by davevalley View Post
    beshvc, The article (at the end) clearly states to replace this line...period. I'm simply attempting to get professional HVAC tech's to chime in with their opinions.
    Sorry, read it again at the end, where does it clearly say that?
    Aug 2010
    buy a flush kit to flush the oil and blow with nitro youwill be fine
    Oct 2012
    Methuen, MA
    I'm sorry...I inserted wrong article. The article I'm referring to is HERE.
    Jun 2006
    Richmond, VA
    That's just an article someone writes to get their search engine rankings up....it's not peer reviewed, in a professional journal or have any references with manufacturer's instructions.
    If you can change it without tearing up walls-change it. If you can't change it- flush with nitrogen.
    Oct 2010
    Quote Originally Posted by beshvac View Post
    X2, I would not use any ac flush solvent just plain nitrogen purge
    burlington county n.j.
    Quote Originally Posted by jtrammel View Post
    X3
