Results 27 to 32 of 32
10-08-2012, 11:05 AM #27
You are asking for widow openings. Letting them run fan is cheaper then driving them to windows. Tight buildings need air circulation.
Wifi thermostats are the true answer. KNOW what the occupants are doing over time rather than guessing. If you make that pitch it even more firmly puts onus of failure and brand of incompetence upon them.Which makes more sense to you?
10-11-2012, 08:27 AM #28
- Jun 2009
- Pompano Bch, S Fla
- 57
10-11-2012, 10:17 AM #29
2c per hour looks like 48c per day which runs out to $15 per month. I think you maybe used 31 days a month and doubled when you should have halved.
10-11-2012, 10:57 AM #30
You guys keep talking about fresh air, and that's why the fan should run... Must likely, though, there is no fresh air intake on these units, so all the fan is doing is filtering, and mixing within the space.
10-11-2012, 06:40 PM #31
10-11-2012, 10:56 PM #32
That only happens if the duct work is perfectly sealed and the house is perfectly sealed.
When equipment runs there is typically positive pressure in one area and negative pressure in another. Often bedrooms have only supplies, and some living space has more returns. The air in the positively pressured space does not cooperatively return 100% to the furnace - it follows the path of least resistance - some of which will be out cracks and leaks in the duct or room. Leakage may increase when doors are closed.
The air in the negatively pressured space does not cooperatively come 100% from the house - it comes from the path of least resistance - some of which will be in cracks and leaks in the duct or room.
So even without fresh air intake, you are getting some amount of "fresh" air.
Whether that "fresh" air is primarily coming from moldy crawl spaces on it's way into poorly paned returns is another matter.Which makes more sense to you?
