Results 14 to 26 of 32
    May 2012
    Upper Michigan
    Just write a note that says "leave fan on" then your guaranteed to have to tenant do the opposite.
    Oct 2011
    Chicagoland Area
    Doesn't anyone open windows anymore?
    Local 597 Service Fitter
    Metal Trade Journeyman
    PAY ME NOW OR PAY ME LATER
    It was working when I left...
    WWFD
    Houston,Tx.
    Not in the sanctuary city of Houston, there was a time we could, but thanks to Katrina not anymore.
    "The critic is a prisoner to his own experiences and perspectives, erroneously believing his limited experiences are the sum of all truth".
    May 2012
    Upper Michigan
    I worked at a house like that, puting air to air in because they can't open a window
    Mar 2012
    New Hampshire
    Quote Originally Posted by zensgreedyfly View Post
    They do not pay the electric bills...Military base
    Thanks LK
    The military isn't footing the bill - we are - And I say "Give them boys the right to choose their own fan option!!"
    Seriously though, what's the point of of having a heating or cooling system if you aren't able to use it how you feel comfortable? Zen, tell whoever asked you to disable the fan-on that they are taking the "V" out of HVAC! Fan-on is way cheaper than AC on, just saying.....
    "I don't know why it be like it is, but it do"
    Aug 2001
    Pavilion, NY
    The furnace does not need G in heating. Disconnect the existing G at the furnace and abandon it. Jumper Y and G at the board. When it calls for heat the board energizes the blower on
    Time and when it calls for cooling the board will receive Y and G and your good to go.
    Tulsa, OK
    Seems like I paid over $5,000.00 for a degree In HVAC,
    and you want an DIY answer as being the landlord to control someones choice of using comfort control you charge rent for! ROFLMFAO !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Jun 2009
    Pompano Bch, S Fla
    How much does it cost to run a fan on a residential unit anyway? I understand about watching your pennies but I can't imagine this saving a substantial chunk of change.
    Nov 2011
    Rant?
    How's this:
    Our society is based upon the low-bidder...it's nothing new. Companies and individuals forget that this is our nature as Americans...we want high quality for low $$ and expect the contractor to foot the bill if there is any issue with his high quality (that I had to shortcut to get his bid). The reality is that the low bidder will install inferior products with substandard workmanship so that he can get the project.
    This is NOTHING new. What we, as dedicated HVAC professionals, fail to realize is that it applies to engineers, manufacturers and distributors as well. Yesterday I had the pleasure of explaining to a mechanical engineer of record (stamp and all on my plans) what happens when the dewpoint reaches the ambient. He had no clue!
    In the end, the companies with the experience and knowledge are left behind in favor of spending less money for someone out of school that wants to learn. I have not only experienced this, I have seven (7) projects in progress ranging from 1.7 to 24.2 million. With the exception of one project, the General Contractor's PROJECT MANAGERS are in their 20's. The one exception is a PM that never shows up and has put one of the Superintendents in charge...again...in his 20's.
    Now don't get me wrong, I have seen more individuals than I care to mention that have 20 years under their belt doing HVAC. Inevitably the first words out their mouths are ALWAYS "...I've been doing this XX years and I say..." Personally, I feel as though if you need to justify your knowledge to have your voice heard after "XX" years then you probably don't have a clue what you are talking about. I can't afford to listen to Mr. "XX" years...I can't afford to listen to fresh-out-of-college GC. I can only rely on my knowledge and the CONTRACT.
    That is why I decided to finally post a question after being a member here for 7 years. I thought I would get some input because I received an "I've been doing this..." response from someone.
    In the end, you know what? I figured it out myself...apparently I've been too bogged down to think straight...maybe I'm getting older...and yes Mr. "toocool", maybe I posted this in the wrong place.
    I don't care gentlemen. I will continue to do the best work that I am allowed to do...BY CONTRACT (because that is how America works). Unfortunate? Absolutley! But I am a fighter and I change with the industry...otherwise I would be saying "I've been doing this for 27 years and I say...".
    really man... really, all that for what, did i miss somthing?
    (((PEACE IS THAT BRIEF MOMENT IN HISTORY WHERE EVERYBODY STANDS AROUND RELOADING)))
    (((YOU SEE A SIX PACK, I SEE A SUPPORT GROUP)))
    Apr 2012
    winnipeg
    let the fan run...let the fan run... let the fan run..... it is not expensive.... tenants deserve it.....
    Madison, WI/Cape Coral, FL
    Quote Originally Posted by carmon View Post
    This about more than let the fan operate in the "on" mode!
    This is about fresh air ventilation when the wind is calm and there is no natural fresh air. All homes need an fresh air change in 4-5 hours when occupied.
    This is about maintain <50%RH when outdoor dew points are +55^F to avoid mold/dustmites/biologicals.
    In an affort to keep the %RH low, the designers are dictating "avoid fan "on" mode. Yes, it helps keep the %RH down, does little to provide overall indoor air quality. This is old thinking. While helping reduce indoor %RH duing low cooling loads, ducts grow mold, circulation of moist, fresh air must be avoided, and the moisture added by the occupants is not removed.
    This is flawed indoor air quality strategy for any green grass climate for any home.
    An air of fresh air in 4-5 hours is must for all occupied homes, not just that can have the best. The buildup of indoor chemical pollutants is affecting health in many suttle ways. The buildup of indoor moisture as generates many not totally understood biolobical pollutants.
    Adding a filtered mechanical fresh air fan and a good dehumidifier allow air circulation, filtering, and real comfort.
    The new small, whole house ventilating dehumidifier is a package that combines all of the needed feature to provide a simple solution to all of the above many IAQ problems and ultimate comfort at a reasonable price. This is the idea of the Ultra-Aire, Honeywell and other small whole house systems.
    Regards TB
    Real indoor air.
    Keokuk, IA
    Quote Originally Posted by Pete954 View Post
    Well if it's a fairly small system and the mtoor only draws 200watts, @ $0.10/kw-hr and if it would normally only run about 30% of the time in "auto", that's $184/yr. That's why for those that like to run the fan continously, a ECM motor can save around $100-150/year in electricity. More when you also factor in the bump in SEER as well.
    Sep 2012
    NW Louisiana
    The blower control board had a bad relay on one of my personal air handlers in my new house. Brand new unit. After the first time I started the unit the relay stuck "ON". My X13 motor ran for about 3 weeks before I obtained a warranty board and replaced it (my fault, more important issues). The electrical usage was probably negligible, or about as much as a 2 bulb motion light. It did keep the air exchanged!
    CT
