Results 1 to 4 of 4
    Sep 2012
    Trane XR15 vs XL15i
    One contractor has bid an XR15, the other has bid the XL15i. Both are bidding XV95 furnaces.
    Based on the specs I found on the Trane site, it appears to me that the XR15 must be a little more efficient, based on electrical requirements. It also appears to be the less expensive of the two.
    Any comments on which is a better choice?
    Thanks.
    D.
    Apr 2010
    NC Sandhills
    The XR15 is a BIT more efficient depending on evap coil, but the main advantage of the XL15i is less noise, slightly better construction and a 12 year compressor Registered warranty vs 10 for XR. I would go with XL if its in your budget.
    Lancaster PA
    Arthurhagar”, this is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise here. Please apply to the AOPC today, thank you.
    Your post has been deleted.
