Results 14 to 26 of 44
Thread: Skeptical A/C Issue
10-03-2012, 08:03 PM #14
- Oct 2012
- 21
10-03-2012, 08:04 PM #15
Professional Member*
- Jan 2012
- indy
- 460
A lot of residential guys are briefly trained and sent out on their own, commercial not so much. So if their not purposely ripping you their just incompitent. Find someone that works for a company that might help you on the side they might be more help
10-03-2012, 08:36 PM #16
A piston is a fixed orifice. All ac's have a metering device to flash liquid refrigerent to begin the change of state from liquid to vapor thus removing the heat from the air in the process. The 3 types of metering devices are a capillary tube(old ac's have these) , txv, or piston (fixed orifice). Some higher end equipment will have an electronically controlled expansion valve (exv).
10-03-2012, 08:48 PM #17"In this house we obey the laws of thermodynamics!"
- Homer Simpson
10-03-2012, 09:05 PM #18
- Jan 2012
- indy
- 460
10-03-2012, 09:44 PM #19
- Oct 2012
- 21
This was from contractor #3 when he did the evacuation of old refrigerant and replaced it with 5 lbs of R-22. The process, BTW, included removal of the old/contaminated R-22, purge with nitrogen (or something like that) and vacuum to 500 microns. Then he replaced it after finding no leaks.
10-03-2012, 11:32 PM #20
- Oct 2012
- 21
10-04-2012, 12:42 AM #21"In this house we obey the laws of thermodynamics!"
- Homer Simpson
10-04-2012, 05:09 AM #22
The readings aren't out of line. but would need to know indoor wetbulb to know if they are ok.
10-04-2012, 09:28 AM #23
- Mar 2004
- Des Moines, Iowa
- 147
This is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise here. Please apply to the AOPC today, thank you.
Further infractions may result in loss of posting privileges.Last edited by beenthere; 10-04-2012 at 04:23 PM. Reason: Non Pro * Member
10-04-2012, 09:44 AM #24
- Mar 2004
- Des Moines, Iowa
- 147
10-04-2012, 10:20 AM #25
X2
From your description you are definatly suffering from lack of experience. Something is causing the coil to freeze and it is definatly not a capacitor on the outdoor unit. Did they replace the Blower motor capacitor, or check the operation of it or see if your indoor coil is cleaned?
10-04-2012, 10:36 AM #26
I plugged your invoice data into my Android phone app "HVAC Buddy", assuming a 67 degree wet bulb for that missing data above. It returned a verdict of "high superheat" and stated possible causes as "undercharge (leak) or restriction".
So there you go. An app on a smart phone reached the same conclusion I and other techs here have. How 'bout that?
- Homer Simpson
Oh my!
