Results 1 to 9 of 9
    Jul 2012
    Everett, WA
    Reach in cooler and Reach in freezer
    I have a buddy that wants me to design a reach in cooler and reach in freezer for his kitchen that are on casters but looks like its just setting on the tile in there that looks like its not moveable and both units run on 115V.
    He wants them to be both the same size of 2.67ft deep x 2.67ft width x 5.83ft tall. Building the box wouldn't be my problem but designing the refrigeration system is where I am needing help.
    What I'm thinking is using a Johnson Controls Electronic Temperature control for both to control the temperature inside and shut the compressor off when design setpoint is reached.
    Jan 2006
    DFW Metroplex
    Sounds like a major undertaking. Why not just look for a couple used reach in units on casters and install a skirt around the bottom?
    "The problem is the average person isnt tuned in to lifelong learning, or going to seminars and so forth. If the information is not on television, and its not in the movies they watch, and its not in the few books that they buy, they dont get it" - Jack Canfield
    Jul 2012
    Everett, WA
    Thats what I said to do, but he didn't wanna do that.
    I think he's crazy for wanting to have it designed instead of just buying one. But he didn't wanna spend over 5k for the one he wanted with tax and delivery. So he wanted to have one designed like that one.
    Southeastern Pa
    Sounds like it is more expensive to build it.
    When it has trouble you "own" it.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Jan 2006
    DFW Metroplex
    Quote Originally Posted by caheiman30 View Post
    Unless you're planning on doing the engineering, material gathering, installation, start up, and warranty work on these units for free and completely out of the goodness of your heart, this gentleman is going to have significantly more than mid $K into this.
    The idea that he's 'cheap' enough to not want to spend the kind of money to have a couple of systems that are professionally engineered and manufactured, but would rather have a 'buddy' put out a similar quality product for less suggests you might want to not just walk away from this.....but run - fast.
    If I remember correctly, we aren't allowed to give step by step info in this particular forum. That said, even if we could, I'm not sure a person, even with my refrigeration acumen, would be able to help you with all the information you will ultimately need to make this happen.
    Is there any way of kinda putting your tail between your legs and tell your friend that while you can fix the hell out of a broken down unit, fabricating a couple of units from scratch is simply not your forte'?
    Jul 2012
    Everett, WA
    I said I would look into the cost and tell him which is going to cost the least amount of money
    Feb 2007
    Georgia
    True makes a commercial combo unit on casters you could dress up like your buddy wants if I remember it was about $3,000.00
    Jul 2012
    Everett, WA
    I will have to look into that
    Nov 2010
    Dude this could be a real PITA. Companies spend alot of coin for engineering and the like. And their assemblers have everything they need RIGHT THERE, with a PLAN for everything from wire routing to door frame heaters.
    I'd run too. If it were easy to build a comparable product to the industry standards everyone would be doing it.
    Sent from my MB886 using Tapatalk 2
Tags for this Thread
