    Apr 2002
    Majestic dv580rfn failure
    Pilot won't stay lit, but will light until the pilot button is released. No 120 to the unit so I have referred to an electrician. I suspect that the valve is bad and am told that the Honeywell valve is no longer made. Why? Question #2 told that the replacement is a Sit valve and all of the components to the burner have to be replaced. Anyoine have experience with this product?
    Frank_G
    No good deed goes unpunished.
    Kingston,Ontario
    Thermocouple and/or thermopile been checked? Company I work for hasn't worked with Majestic for a long time now, memory is kinda fuzzy, but those have an LED light on them don't they?
    Found the manual.
    http://www.docstoc.com/docs/10052875...DF-download%29http://www.docstoc.com/docs/10052875...DF-download%29
    Apr 2011
    Ontario
    Majestic is long out of business, i would test the thermopile and thermocouple first, even give it a good cleaning then try again.
    May 2008
    Wichita, KS
    Majestic is not out of business. See http://majesticproducts.com/.
    Bart Ogden
    Wichita, KS
    Bart Ogden
    Wichita, KS
    CSIA Certified Master Chimney Sweep
    CSIA CDET Dryer Exhaust Technician
    NFI Master Hearth Professional
    Notice: Advice given is general in nature. Local laws and ordinances may govern and/or supersede the information and recommendations provided. Final determinations are the responsibility of a local qualified industry professional with first-hand knowledge of the situation, and the AHJ.
    Nov 2009
    Simcoe, ON Canada
    Majestic is now owned by Monesson Hearth. They have valve conversions available for the Honeywell systems. Any Majestic dealer can get the parts. Or you can contact Monesson and they can direct you. I have done 3 or 4 of these valve conversions in several models freestanding stoves are worse than the builtin or inserts.
