Page 3 of 3 FirstFirst 123
Results 27 to 33 of 33
  1. #27
    Jun 2002
    south jersey
    I love it when the mods joke around with each other. Shows there not always grumpy old dudes.LOL.
    You need to put the phone down and get back to work!
  2. #28
    Mount Airy, MD
    Quote Originally Posted by jnsrose View Post
    Beenthere is the old and grumpy one...... I am the not so much younger and handsome one....
    Although he is the one with the picture of the booth girl last go around
  3. #29
    Southeastern Pa
    First, get your post count up and apply for Pro status, so you can ask techncial questions in the closed Pro forums.
    Second, you mentioned a hard start kit. It that kit uses a PTC, it will not be able to assist the compressor until it has fully cooled off. A potential relay hard start will assist EVERY time. So, you need to find out if you have a good hard start kit there.
    Question: when the compressor fails to start, have you cut the power to the unit and ohmed out the windings? You could be going out on internal overload, so all you will get for resistance is OL.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  4. #30
    Jan 2011
    southern ohio
    thanks for all the info guys had a weak start winding they replaced it with a scroll compressor still had 3 months on warranty. reto kit worked great and was covered also new scroll did not have heater so installed a belly band heater. had to cut reversing valve out made job much easier and quicker
  5. #31
    Athens, Ohio
    Quote Originally Posted by rustneversleeps View Post
    Had to cut out the reversing valve??!!
    RVs are a pain to change - 4 pipes as compared to two on a compressor. And RVs are much touchier to braze, especially when you have to lean over the top of the unit to do so.
    I'd much rather change a compressor than a reversing valve.
  6. #32
    Jan 2011
    southern ohio
    hey there ken, I'm mike I worked for O.U. in the a/c shop. Worked with Phil and Cecil
  7. #33
    Athens, Ohio
    I know them well. We worked together at DWS.
