Results 14 to 26 of 27
    Feb 2012
    I only had the 1st generation NEST and my contractor asked me how I wanted to hook up my 2 stage Goodman. He said either just hook up stage 1 or combine the 2 stages so it's always running in stage 2. The Tstat wire run is 5 wires but really, we need 7 so that the upstairs NEST can use Rc Rh G Y1 Y2 W1 and C. I'm learning that the NEST is what is termed a "power robbing thermostat" so you really need the C wire to provide a constant charge to it.
    I have in-floor radiant heating with 3 zones. I have 2 NESTs for 2 of the zones (the basement zone is not hooked up yet) and the AC is directly connected to the 2nd floor NEST.
    I'm considering the 2nd gen NEST but need 7 wires. I had my contractor come back after the initial install to think of a way to get the C wire so he used a Venstar Add-a-Wire. He's not familiar with Add-a-wire units that can add more than one wire. I'm trying to convince my contractor that the ARGO unit he's using needs the Isolation Relay because the NEST is dependant right now on the AC power wires Rc and C for it's power. If I turn off my Spackpak unit, the NEST reports no power at Rh as well. I think I need the Isolation Relay for this to work properly.
    Thanks for all the responses!
    Aug 2012
    Why don't you just use the proper tstat or have the tech run a new wire?
    Feb 2012
    I'm planning on getting the proper NEST but running a new wire from the basement to the 2nd floor in a finished house isn't something I want to have done. The Tstat wire were run during the reno when it was just studs and no drywall / paint. I'd rather use a solution like the add-a-wire but to get 2 more wires instead of just one more.
    Aug 2012
    wireless t-stat?
    Feb 2012
    I was thinking to suggest one of these Fast Stat modules...
    Vision Pro HD thermostats, 2 wires. Plus you can use the redlink to access it from the internet.
    Rochester NY
    Charting?
    Name:  ecobee  web interface - Google Chrome 1022012 91439 PM.bmp.jpg
    Don't know. i didn't break down and get one for my place yet.
    Rochester NY
    That's a screenshot from one of my ecobees. You can get 2 under a pro deal.
    Or, you could just send me one. LOL Then I could compare it to the HD.
    Does/can the Ecobee use an outdoor sensor for dual fuel control.
    As shipped it will use the weather data from the internet feed for the outdoor temperature for dual fuel control, and the displayed outdoor temperature on the thermostat.
    If you want an actual outdoor temperature sensor, you have to get the optional remote sensor module.
    The remote sensor module has connections for 4 remote sensors. All 4 will work with commonly available 10 kohm thermistors, and 2 will work with 0-10 or 0-5vdc humidity or CO2 sensors.
    Quote Originally Posted by lithiumus View Post
    He needs to look into the Fast-Stat brand, much better selection of products than the Venstar, and higher quality.
    Jun 2001
    The ecobee will do everything the nest does and only requires 4 wires from the stat to the equipment. Costs about the same as nest also.
    Athens, Ohio
    Or the Prestige 2.0 IAQ which can do multiple stages, dual fuel, ventilation, humidification, de-humidification, return and supply temperature monitoring, display indoor and outdoor temps and humidity, plus access from smart phone, tablet and online. And it can send e-mail alerts if the temperature goes outside your chosen settings. All with just 2 wires.
