Results 1 to 8 of 8
    Nov 2011
    South Texas
    Looking for RTAA-SB-10 bulletin
    I am putting together a notebook of information on this one series of chiller to keep in my truck. Does anyone have this bulletin. I can call trane in the morning but figured someone here is bound to have it and would not mind sharing. Thanks Chris
    Mar 2011
    North Carolina Piedmont Area
    I have a lot of literature on the RTAA but I dont have that one. What is it about? If its important I will have to ask my Trane for it.
    Mar 2011
    This is what I got:
    RTAA-SVX01A-EN: Installation Operation Manual 70-125 Ton Dated Sept 2005
    RTAA-IOM-3: Installation Operation Maintenance 130 - 400 Ton.
    RTAA-IOM-4A: Installation Operation Maintenance 70-125 Ton.
    RTAA-W-1: Wiring 130-200 Ton
    RTAA-W-2: Wiring 130-400 Ton
    RTAA-SB-4: Slide Valve Operation Troubleshooting.
    RTAA-SB-5: Control Operation, Set Up, and Troubleshooting Control Panel.
    RTAA-SB-7: EXV Motor Drive Failure.
    RTAA-SB-9: Control Operation, Set Up, and Troubleshooting the UCM Microprocessor for RTAA 70-125 Ton with Clear Language Display (CLD)
    N/A RTAA-SB-10: RTAA 70-400 Ton Refrigerant Pump Down /Evac Procedures, Connection Points, and oil Circuit Repair.
    RTAA-SB-12: Troubleshooting High Pressure Cut Outs and Low Oil Flow Diagnostics.
    RTAA-SB-18: RTAA 100 Ton Compressor Lip Seal Failures
    RTAA-SB-21: Upgrade to Fan Staging for RTAA 130-400 Ton.
    RLC-SVD03A-EN: Diagnostic Trouble Shooting Repair 70-125 Ton
    COM-18 CHHN and CHHB Screw Compressor Application
    EMTX-IOM-3 Installation/Operation/Maintenance for DDC Chiller Sequencer
    Quote Originally Posted by alcomech View Post
    This is what I got:
    ...N/A RTAA-SB-10: RTAA 70-400 Ton Refrigerant Pump Down /Evac Procedures, Connection Points, and oil Circuit Repair.
    it appears that you have the bulletin he is looking for.
    Time to get my nerd on!
    Mar 2011
    I don't have the following Service Bulletins:
    RTAA-SB-7: EXV Motor Drive Failure. (I don’t have this one)
    RTAA-SB-9: Control Operation, Set Up, and Troubleshooting the UCM Microprocessor for RTAA 70-125 Ton with Clear Language Display (CLD) (I don’t have this one)
    RTAA-SB-10: RTAA 70-400 Ton Refrigerant Pump Down /Evac Procedures, Connection Points, and oil Circuit Repair. (I don’t have this one)
    I found one more in my files which I do have:
    RTAA-SVD01A-EN: RTAA/CHHB Compressor Troubleshooting
    Nov 2011
    South Texas
    I went ahead and called trane and found it the next morning. Thanks for trying though that list of TSB's had a couple I hadn't seen and make for good reading
    Mar 2012
    Finland
    Can someone send me these service bulletin's via email, or give me a link to right place to download..
    dania,fl
    please email me the rtaa sb's
    ck33004@comcast.net
