Results 1 to 13 of 21
    Nov 2011
    South Texas
    Looking for RTAA-SB-10 bulletin
    I am putting together a notebook of information on this one series of chiller to keep in my truck. Does anyone have this bulletin. I can call trane in the morning but figured someone here is bound to have it and would not mind sharing. Thanks Chris
    Mar 2011
    Long Beach, CA
    I have a lot of literature on the RTAA but I dont have that one. What is it about? If its important I will have to ask my Trane for it.
    Mar 2011
    Long Beach, CA
    This is what I got:
    RTAA-SVX01A-EN: Installation Operation Manual 70-125 Ton Dated Sept 2005
    RTAA-IOM-3: Installation Operation Maintenance 130 - 400 Ton.
    RTAA-IOM-4A: Installation Operation Maintenance 70-125 Ton.
    RTAA-W-1: Wiring 130-200 Ton
    RTAA-W-2: Wiring 130-400 Ton
    RTAA-SB-4: Slide Valve Operation Troubleshooting.
    RTAA-SB-5: Control Operation, Set Up, and Troubleshooting Control Panel.
    RTAA-SB-7: EXV Motor Drive Failure.
    RTAA-SB-9: Control Operation, Set Up, and Troubleshooting the UCM Microprocessor for RTAA 70-125 Ton with Clear Language Display (CLD)
    N/A RTAA-SB-10: RTAA 70-400 Ton Refrigerant Pump Down /Evac Procedures, Connection Points, and oil Circuit Repair.
    RTAA-SB-12: Troubleshooting High Pressure Cut Outs and Low Oil Flow Diagnostics.
    RTAA-SB-18: RTAA 100 Ton Compressor Lip Seal Failures
    RTAA-SB-21: Upgrade to Fan Staging for RTAA 130-400 Ton.
    RLC-SVD03A-EN: Diagnostic Trouble Shooting Repair 70-125 Ton
    COM-18 CHHN and CHHB Screw Compressor Application
    EMTX-IOM-3 Installation/Operation/Maintenance for DDC Chiller Sequencer
    Quote Originally Posted by alcomech View Post
    This is what I got:
    ...N/A RTAA-SB-10: RTAA 70-400 Ton Refrigerant Pump Down /Evac Procedures, Connection Points, and oil Circuit Repair.
    it appears that you have the bulletin he is looking for.
    Mar 2011
    Long Beach, CA
    I don't have the following Service Bulletins:
    RTAA-SB-7: EXV Motor Drive Failure. (I don’t have this one)
    RTAA-SB-9: Control Operation, Set Up, and Troubleshooting the UCM Microprocessor for RTAA 70-125 Ton with Clear Language Display (CLD) (I don’t have this one)
    RTAA-SB-10: RTAA 70-400 Ton Refrigerant Pump Down /Evac Procedures, Connection Points, and oil Circuit Repair. (I don’t have this one)
    I found one more in my files which I do have:
    RTAA-SVD01A-EN: RTAA/CHHB Compressor Troubleshooting
    Nov 2011
    South Texas
    I went ahead and called trane and found it the next morning. Thanks for trying though that list of TSB's had a couple I hadn't seen and make for good reading
    Mar 2012
    Finland
    Can someone send me these service bulletin's via email, or give me a link to right place to download..
    dania,fl
    please email me the rtaa sb's
    ck33004@comcast.net
    Nov 2010
    Sao Paulo, Brazil
    Hello alcomeh, could you share these SB's with myself?
    I really appreciate if you could! Regards!
    If you coud plese e-mail me
    Mar 2011
    Long Beach, CA
    Check your mail
    Jul 2013
    Illinois
    Could you please share with me also, I have a few of these and don't have all of them either, thank you in advance.
    Mar 2011
    Long Beach, CA
    There is a lot of info on this unit. send me a list of the PDF you want and I can forward them to you
    Jun 2014
    Forked River, New Jersey, United States
    Alcomech just came across this thread and have been searching all day for RTAA-SVD01A-EN Any chance you could send it to me? my email is Please put your email address in your profile, they are not allowed in post. Thank you. It would be greatly appreciated Thanks in advance
  14. Likes Zahrouni liked this post
