Results 1 to 13 of 23
    Sep 2012
    Confused 2-stage packaged unit efficiency vs split system
    We need to replace our 13 years old packaged unit. We live in North California.
    I know that packaged units are limited to 80% efficiency, and for that reason I was planning to get a split system with ~95% efficiency.
    But my contractor tells me that with a good 2-stage, variable-speed packaged unit, the difference in operating cost due to the 80 vs 95% efficiency difference becomes minimal. He says that since the system will run at reduced speed most of the time, the split system would not really save me an additional 15% in operating cost.
    On the other hand, he says that since we already have a packaged unit, simply replacing the packaged unit would result in ~ in installation cost, compared to installing the split system.
    What do you think? Is his efficiency vs operating cost argument correct?
    I still prefer the look on a split system, but if this means more and if we don't have a substantial operating cost reduction, then we may stick with a packaged unit.
    Thanks in advance for your help!
    Oct 2010
    To get a 95% furnace it will likely be 2 stage, so you will have the 15% increase. A package unit cannot be over ~80% afue because anything above it starts condensing, making water, which could freeze in the winter. I don't know why manufacturers don't make a 90% package unit because it would be easy to do, but that's a whole other discussion. It would cost more to go to a split due to duct revisions and labor time vs a package change out.
    Sep 2012
    Both 2-stages
    Quote Originally Posted by jtrammel View Post
    Yes, both the packaged and split systems are all same configuration (both 2-stages, both variable speed). Only the efficiency is different. Still , he was saying that at low speed, that 15% difference becomes much less. I tried to get an actual number from him, but all he said is that it would end up being a few dollars difference per year. I can see that it is difficult to put a number on that since we don't really know at what speed and burner level it will be running at, but I was surprised to hear that 15% would become insignificant.
    Thanks,
    Benoit
    Virginia
    Depending on your gas rate and electric rate a dual fuel package unit might be a good option carrier and trane both have them readily available
    Thank God Trump Won
    Oct 2010
    Quote Originally Posted by Benoit View Post
    Thanks,
    Benoit
    I don't know how he comes up why that, maybe someone else can shed some light on the topic. As for dual fuel package units most manufacturers if not all of them have that equipment readily available
    I don't buy that 15% is insignificant. BUT since you aren't in a real cold climate. I was thinking along the dual fuel line myself then I saw it brought up already. The cost to go split system 95% over staying packaged probably will negate any savings, something to keep in mind.
    Why no 95% pack? From what I've been told these are the 2 most common reasons: packs are usually used in the south so little need for the super efficiency. Also, packs are used light commercially and utility bills are paid by tenants so there would be little call for anything but the cheapest units.
    Sep 2012
    Thanks for your inputs!
    I read somewhere that to get higher than 80% efficiency, the required process generates condensation. If left outside at cold temperature, this condensation can freeze and cause numerous problems. Since a split system is inside, the condensation is simply collected and sent down the drain.
    By dual fuel you mean electric + fossil (in my case, propane), correct? I was told that electric, in addition to being more costly to operate, is also not as comfortable because of the slow turn-on. But maybe this does no apply to dual fuel systems since electric is only used when quick/strong heat is not needed? Another reason why dual fuel may be interesting is that in the future we will install solar panel and hopefully we will generate enough power to reduce the heating costs with an electric furnace.
    From my calculations it seems that IF the 15% savings are still there for the split system, then the increased installation cost is compensated by the operating cost over the next 6 years. After that, I start really benefiting from the reduced operating cost for many years.
    So many variables can throw off these projections, but is that realistic?
    Thanks,
    Benoit
    Propane? You are definitely a candidate for dual fuel. In our climate, the gas backup will hardly come on meaning cheap heat from the heat pump. We've been doing it for several years with nary a complaint. Get a control that handles the dual fuel and have it switch to gas at 30°. you will be comfy.
    Oct 2010
    X2 propane is expensive, heat pump would be a better choice or dual fuel
    Sep 2012
    We live in a rural area with no connection to the city utility. Except for electricity, we're on our own (septic, well, propane tank...).
    So the dual fuel can be electricity+propane?
    Thanks.
    Oct 2010
    Thanks.
    Yes electric heat pump with propane for back up heating
    Jun 2001
    Before selecting propane as backup fuel, compare to the cost of electricity. In our area electric heat strips are actually CHEAPER than propane.
    Virginia
    If you are on dominion power heat strips are cheaper to operate than propane at least in my area .
    Thank God Trump Won
