    Dec 2011
    Manila Philippines
    How to connect a Johnson Controls NAE35 to wifi?
    I have 1 NAE35, 1 PC, 2 Laptops, and 1 wireless router with 1 WAN, 3 LAN ports in the office. What else do I need so I can monitor and control the NAE35 system? and How I can do it?
    Quote Originally Posted by BACNet Jr. View Post
    Is the NAE a existing unit? What IP address does it have currently.
    Once you know that, you connect the NAE with a network cable to one of the LAN ports. If the NAE is setup with DHCP, it'll get a IP address from the router. Then using your laptop, wireless or connected to a lan port, you'll be able to log into the NAE.
    If the NAE has a static IP address, you need to make sure thats' it's part of the IP scheme of the rotuer table.
    Nov 2005
    Shreveport, Louisiana
    As stated above. Do you know how to commision an NAE.
    UA Local 141
