Results 1 to 6 of 6
    O.B.X
    No Words for this one
    Click image for larger version.
    This is the first horizontal piece of duct coming off of a brand new water to air Bosch H.P. system. JUST SAD....... Next up the return
ID:	312671 Really sad....
    Now, time for me to come clean... This is a call back on the install department where I work. Disappointing is an understatement.
    I personally believe if it's a warranty for install, the installers should be the ones fixing it. If the same issue arises again, you need new installers. unfortunately; that doesn't occur very often.
    O.B.X
    I mis typed that.... This is the company that I work for.... This will be a call back on the same ****er who was there the first time
    O.B.X
    It's just sad that these installers would even think about doing this sloppy work... Who does this and expects to still have a job, or any respect at work?
    Dec 2010
    Woodbridge Twp, NJ
    I guess they figured round holes of proper size are overrated.
    Every customer you take for granted today will be someone else's tomorrow.
    Quote Originally Posted by elevatedvagabond View Post
    unfortunately it happens all to often where I work and there are ZERO consequences!!!!!!
    caught same installer on 2 different jobs months apart that was too lazy to pull new stat wire for PRO8000 stats, yet wrote down he had.
    I pulled the wire, reprogrammed the units and turned in the wire to prove he did NOT, along with photos. he got talked to and nothing else.
