Results 1 to 13 of 28
Thread: capacitors
    Aug 2012
    capacitors
    Is there any way to determine what size capacitor a motor uses without any info but the from the motor itself?????
    Sep 2012
    Hebderson Ky
    Call the local supply house or look on the data plate.
    Sep 2012
    Hebderson Ky
    Data plate on the motor.
    Aug 2012
    Indeed , but on compressors thay do not give this info and late at night with no way to tell i guess there is not a magical solution?
    Sep 2012
    Hebderson Ky
    You are correct compressor do not. Not for sure where to find it on an after hours call.
    Aug 2012
    Richmond, Virginia
    Smartphone knows
    Aug 2012
    Smartphone maybe the way to go then. At any rate A good guess got them thru.
    Aug 2009
    Griffin, Georgia
    If it is on a Copeland compressor Copeland makes an electrical handbook for all of their motors and units. You can get one at most supply houses. I highly suggest it. I can't count how many times its been midnight on a Friday or Saturday and I go to the book and find out what relay or capacitor I need.
    Sent from my DROID RAZR using Tapatalk 2
    Sep 2012
    Hebderson Ky
    That's good to know. Have to get me one now.
    Dubai
    Quote Originally Posted by toocoolforschool View Post
    First measure the voltage between the two points from running capacitor. Then measure the amps to start winding. Then use the equation below mentioned
    2653*amps/volts
    Ex: 2652*6/347=46 micro farad
    Moideen-Dubai
    Lancaster PA
    Quote Originally Posted by moideen View Post
    2653*amps/volts
    Moideen-Dubai
    That will tell you what uF the working cap is. but won't tell you if its the right size cap. And if the cap is bad, and the label is not readable, you won't know what size cap to use.
    Copeland has a manual with the cap listed for each compressor they make.
    Tallahassee, FL
    Johnstone catalog is free and has lots of listings.
    Here is a Bristol guide I acquired.
    Quote Originally Posted by SBKold View Post
    Do .you have one for Copeland?
    Bristol is a dying breed
    Mostly Copeland
