Results 14 to 17 of 17
Thread: Noisy duct work
    Aug 2010
    West Monroe, LA
    If it was installed new with your furance? I would give your installer a call and see if they will come out and correct the issiue... If it has been over a year that might charge you but then again they might not. Ask them when the repair is made what caused it to happen.
    Most companies should not have a problem correcting at no charge if it was something they done wrong.
    Feb 2012
    AR
    Quote Originally Posted by luca1 View Post
    The ductwork is right where the air conditioning condenser (I hope i got the name right ???)is located above the furnace, is there a chance a screw could cause damage?? could it be crazy glued on ??
    This is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise here. Please apply to the AOPC today, thank you.
    icehot3006, this is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise here. Please apply to the AOPC today, thank you.
    Your post has been deleted.
    south louisiana
    wonder how it worked out....
