Results 1 to 13 of 17
Thread: Noisy duct work
    Oct 2011
    Hmm Noisy duct work
    I have finally found the duct work that makes noise when the fan on the furnace shuts off. It is found just above the actual furnace and would be a pain to take out. The sheet metal buckles when fan is on and then retracts when fan shuts off and makes a bang noise. My question is, can i crease the metal somehow with out taking it out ??? or is there another way of keeping the metal from buckling without creasing the metal? any tricks of the trade
    burlington county n.j.
    screw a piece of angle metal across the popping section.
    Oct 2010
    Anderson SC
    Quote Originally Posted by t527ed View Post
    X2
    Oct 2011
    The ductwork is right where the air conditioning condenser (I hope i got the name right ???)is located above the furnace, is there a chance a screw could cause damage?? could it be crazy glued on ??
    Mount Airy, MD
    Thread relocated to AOP
    Jan 2001
    Pamnyra VA.
    Identify what is causing the problem.you're only band aiding an underlying problem.
    Oct 2011
    Quote Originally Posted by skibme View Post
    When ductwork was installed it was not cross creased on the one side like the other 3 sides therefore it now flexes.
    Delaware
    How long has it been installed?
    Always here
    Oct 2011
    Quote Originally Posted by energy star View Post
    A little over a year
    Delaware
    Did it make the noise before the new system was installed? Or is this a new house?
    Always here
    Oct 2011
    Actually this is a new piece of ductwork that was installed when new furnace was installed. I'm not sure what it is called but it is the ductwork that the evaporator coil sits in ??
    Lancaster PA
    Plenum.
    Post pic.
    Delaware
    Air flies out your supply vents doesn't it?
    Always here
