Results 1 to 13 of 15
    Sep 2012
    Oil visible in liquiid line sight glass?
    Hello I am working on a 35 ton packaged roof top unit with a copeland semi hermetic compressor. I got sent to this site, spoke with building operator he has been resetting the oil failure control ( not good!) I checked over system
    -net oil pressure is 50 psig
    -suction pressure is 63 psig (loaded)
    -head pressure is 150 psig
    -compressor amperage is running at RLA
    -liquid line sight glass has visible oil bubbling in it
    -outlet of the txv, distributor is cold and condensation on feeder tubes
    - the compressor does not sound very good, would this be reason for poor oil return
    thanks for help
    East of big city prices.
    What refrigerant we talking here R-22? Seems your head pressure is low and affecting your oil return.
    Mar 2009
    Mid-Mo
    Agreed also the head pressure seems low. You haven't given us much to work with though. How can you be sure it's oil and not vapor or liquid refrigerant? How about superheat, outdoor temp, subcooling, etc?
    net oil pressure (if it is calculated accurately ) is ok (trip is 9 psid)...but how do you know that it is oil that is bubbling in your liquid line sight glass? i have never seen oil 'bubble' except when heated. i suspect that there is at least 1 other problem.
    Nov 2007
    Mississippi
    What's the oil level in crankcase sight glass?
    The Zone
    Sight glass could be discolored looking like oil?
    It's Hammer Time!
    Apr 2012
    winnipeg
    never seen oil bubble in a sight glass.... oil travels no doubt but seeing it not to likely
    May 2010
    Oxford, UK
    Seen something similar,
    http://www.youtube.com/watch?v=py_2yOCgKZI
    What oil and refrigerant is the system running on?
    Feb 2012
    Toronto Canada
    ^^^^^^^ Click on the video after that one thats called "Refrigeration system full of water" Looks like the guy pulls 6L out of a system he watches the sight glass lower of water LOL
    To the OP I am not sure how you know its oil that's doing that? I have never seen or heard of it. You give some more info someone should give you a lead in the right direction.
    Dec 2010
    On a Peninsula in NE NC
    Gotta ask, op how do you know its oil.
    But just food for thought compressors usually start pumping oil out just prior to destruction.
    Give us some more info. And why is the oil failure switch tripping? Bad switch, refrigeration problem?
    May 2002
    Only time I have seen oil droplets hanging on a sightglass ,when the system was or wasn't running was when I started up a large 134a system that had mineral oil in the comps instead of poe.
    I questioned this BEFORE startup and was ordered to run with it as it was ordered with the correct oil .
    The result was poor or no oil return ,the oil in the sightglass and other issues .
    The result ,,,two days with cases of the correct oil , buckets ,and an oil refractometer and plenty of rags until I had it confirmed the oil ratio was acceptable.
    mikeacman
    Mar 2009
    Mid-Mo
    Quote Originally Posted by monkeyspanners View Post
    That's really wild, I don't know how I'd react if I saw that for my owns eyes. I'm thinking I'd be getting the recovery pump and tank out.
