Results 1 to 13 of 14
    Aug 2010
    Northern Cali
    NO WATER IN SIGHT!
    Well I am just curious .....What pump sprayer do you use to clean coils when NO WATER in sight ! Which ones work best for you?
    Dec 2010
    On a Peninsula in NE NC
    I do not, I make the facility provide a water tap within reasonable distance of equipment to be serviced.
    It's hard to stop a Trane. but I have made one helluva living keeping them going.
    Aug 2010
    Northern Cali
    ya I feel like it should be a LAW to have water on all commercial or restaurant rooftops.
    Oct 2005
    B.C. Canada
    I beleive around here it has become somwhat of a standard on all new buildings, however, that doesnt help on old buildings... I refuse to carry 1000 feet of hose in my van!! That being said, we have lota hose in the shop, i grab it when i know i will need it.. PITA!!!
    Mount Airy, MD
    Double row coil and a pump sprayer?
    Not happening
    Oct 2005
    B.C. Canada
    Quote Originally Posted by Chris_Worthington View Post
    Not happening
    My thoughts exactly!
    Aug 2012
    Palmyra, Missouri, United States
    water heater
    Oct 2005
    B.C. Canada
    Quote Originally Posted by drife678 View Post
    water heater
    Thats dang heavy to carry up to the roof!! :-)
    Salt Lake City/Tooele
    Can't remember who to give the credit to, but it was about hauling hoses. And they brought up the fact they used Soda Fountain hose with hose fittings and have it in on a reel. I have two, two hundred foot lengths on extension cord reels, now. Hose is small enough in diameter it keeps pressure perfect from a distant location, at the same time burst pressure is higher than a garden hose. No more carrying a ton of space consuming hoses. With ball valves at either end, don't worry about them leaking and draining in the back of the truck either.
    Only been skunked a few times with 400ft of hose.
    Oct 2002
    Plano, TX
    There are plenty of industrial, remote sights that there is no water within a mile.
    We do it one of two ways.
    20 gallon truck mounted water tank tied to a small pressure washer. This does a great job with a little water.
    20 gallon water tank using a water well pump. This goes through water pretty quick.
    SS pump up sprayer modified with a hose bib. Full pressure, but requires pumping and won't last long. Couple this with a small pressure washer and you are truly mobile.
    Quote Originally Posted by timjimbob View Post
    I used to do that and it worked wonder. Today, I got better idea - Budlight and strong bladder
    Ohio
    I show up in my Coil Washer Truck #2.
    6000 gallon stainless tank.
    515 gallon stainless steel chemical (coil cleaner) premix tank
    Six inch 2400 GPM cab controlled top mounted turret
    Twin Waterous 1200gpm pumps
    Two inch cab controlled bumper turret
    Since going with this set up I have had to replace a lot of coils and a few smaller 2 ton condensers were never located after washing.
    I am rethinking my plan of attack next summer.
    Nov 2007
    Mississippi
    Trailer with 300 gallon tank and pressure washer mounted on it.
