Results 27 to 39 of 64
09-27-2012, 02:57 PM #27
I think, in my case, I'd rather run a water-to-water chiller with an outdoor fan coil for excess heat rejection, than a reversing heat pump type setup. With a water to water, you could run the chiller as necessary to cool the chilled loop and reject to the hot loop, and if the hot loop is over a set temp, run it through the outside coil. This would maximize the ability to recover waste heat from the chiller (and use it for domestic hot water). If hot loop temp is low, it would be supplemented with a high efficiency gas water heater.
With this type of setup, it would be possible to build a 'central plant in a box' type setup, that contained the controls, cold water supply and return, hot water supply and return, and a outdoor (or ground loop) coil supply and return. If gas is an option, it can be installed on the hot loop. In residential uses, I see no reason why you can't use the same loop for heating and domestic, as long as all components are domestic water rated. This type of box can include the pumps, chiller, etc. Accessories such as storage/buffer tanks, etc can be added, as can other items such as solar heat.
There's also no refrigerant work with a box like this. It's a self contained appliance, just like a refrigerator.
09-27-2012, 04:08 PM #28
I haven't checked it at low temps, it was in ac season when we installed all of the equipment and someone at the church changes filters and cleans coils etc. we havnt been back and it was installed 6 years ago. No complaints of it not meeting the heat/cool demand with no backup heat. It's a 5 ton model that serves 6 small fan coils the rest of church is dx York predators
09-27-2012, 04:14 PM #29
Pricing isn't that bad it's just a heat pump with a pump, tank, and coax hx. It is a small operation right up the road from me in South Carolina
09-27-2012, 04:50 PM #30
Made this its own thread in Tech to Tech, since it has little to do with the thread it was in.
09-27-2012, 06:08 PM #31
- Sep 2012
- Central Florida
- 678
I know these are commercial but they would be close to what your talking about. They don't have any water tanks though. They actually are pretty small boxes at the lower size, 28x28x19, like I said there are only controls for the refrigerant cycle. These are 410a based off of copeland scrolls. They can be configured for heating, cooling or reversible.
http://www.daikinmcquay.com/mcquaybi...s/Cat_1107.pdf
09-28-2012, 06:35 PM #32
Waterfurnace also makes some nice water-to-water units, down to I think 1.5 ton, and I think they DO have water temp based controls.
09-28-2012, 09:29 PM #33
Professional Member*
- Jan 2008
- Dallas ,Texas
- 3,507
UA 100
It takes three people to do anything around here. Two do the work, one explains to the crowd of people who showed up when they seen smoke and flames.
09-28-2012, 11:20 PM #34
We had a little old lady that had a chiller on her house. Her husband that passed away was a retired submariner. When he retired he made their basement into a mock submarine right down to the watertight hatches in all the doorways. For his submarine basement ductwork was not going to fly so he made a chiller. The shell in tube was inside hanging on the wall with a TXV.(it just might have been the smallest chiller barrel I have ever seen) It was hooked to a 5 ton trane outside. She had a boiler for heat of course. This was the sharpest home built systems and worked excellent. When we were done servicing the equipment the fella I was with told her due to the boiler age it might not be a bad idea to have a carbon monoxide detector. She laughed and said, "At my age you look foreword to dying in your sleep. I don't think I will be buying one."
09-29-2012, 09:43 AM #35
09-29-2012, 10:44 AM #36
- Jan 2008
- Dallas ,Texas
- 3,507
UA 100
09-29-2012, 03:19 PM #37
- Jan 2008
- Dallas ,Texas
- 3,507
10-02-2012, 09:02 PM #38
Well, maybe not if you had something like this.
I have also looked into different "stuff" for residential use like Absorption Chillers and water-to-water like CraziFuzzy has mentioned. I would like it not only being for humidity control, but also maintaining a set temperature. DX is always going to be a "see-saw" if you want efficiency with it. I would do the same thing that Crazi said earlier in post #27, but at this point I don't think any major mfg. is real close to having a residential chill water rig. I wish someone did, I would be the first in line!"If you can't explain it simply, you don't understand it well enough”
Albert Einstein
"Don't you just love when the flames burn off the wiring schematic?" hvacvegas-HTALK member
10-02-2012, 10:26 PM #39
- Jan 2008
- Dallas ,Texas
- 3,507
UA 100
