Page 3 of 3 FirstFirst 123
Results 27 to 35 of 35
Thread: stupified
  1. #27
    Tampa Bay, FL.
    I'm with you SLCTECH. I have 4 of these!Name:  ImageUploadedByTapatalk1348833480.736600.jpg
  2. #28
    Palmyra, Missouri, United States
    Brilliant
  3. #29
    Toronto, Canada
    Quote Originally Posted by drife678 View Post
    Brilliant
    X2
    Ill be adding these to my arsenal
  4. #30
    Salt Lake City/Tooele
    You know I started with these, but there are so many times I couldn't connect to a system for what ever reason because of the stubby solid connection, that is why I dumped the fitting and added a the hose instead.
    Quote Originally Posted by hydra View Post
  5. #31
    Apr 2012
    Louisiana
    Quote Originally Posted by gravity View Post
    I use my digicool ak900. have hoses with ball valves. after i take my readings i close the ball valves, remove both hoses from ports and hook liquid line hose to suction valve and suck it back in. on PM's my company says check temp split. i have seen plenty of units with good deltas but overcharged, undercharged, bad txvs, etc.....
    Do you purge the liquid hose with the suction before you hook up?
  6. #32
    Tampa Bay, FL.
    Quote Originally Posted by slctech View Post
    I gotcha. I'm using them on flexible service valves for refrigeration so I'm able to bend them a little as necessary.
  7. #33
    ...Gauge does upto 800psi so covers the spectrum of 99% of what I would attach it to...
    what are you working on 1% of the time where the pressure is over 800 psig?
  8. #34
    Quote Originally Posted by jayguy View Post
    CNG compressors, I have been servicing and maintaining numerous CNG compression equipment for years. From residential FuelMaker systems to Gas Station rack systems.....3000psi plus...so this could count as my 1%
  9. #35
    that would do it.
