Results 1 to 13 of 13
Thread: txv
    Sep 2011
    txv
    its there diffrent beetern txv for stright air and a heat pump ? had a stright aire unit out they replaced with heat pump its blows cold but not much hot in heating mode small pipe is cold . contractor told me its txv need to be replaced hp model is trane 1100 built 2001 ?he also said temp beetwen intake and output its around 12 ? thx for help
    Jun 2001
    Coil doesn't match outside unit, good luck getting it to perform correctly in both heat and cool.
    Oct 2010
    Quote Originally Posted by 54regcab View Post
    X2
    SW Wisconsin
    Quote Originally Posted by hochla01 View Post
    is there different between TXV for straight air and a heat pump?
    had a straight air unit out they replaced with heat pump its blows cold but not much hot in heating mode small pipe is cold.
    contractor told me its TXV need to be replaced hp model is Trane 1100 built 2001? he also said temp between intake and output its around 12-F? thx for help
    Heat pump TXVs have ball check valves in them & must be used with a heat pump application, plus be for the correct refrigerant & tonnage.
    If the conditioned space is around 50% relative humidity the temp-split is usually around 20-F; it would take a very high relative humidity level to drop the split to 12-F.
    Yes, the indoor coil must match the HP application.
    Sep 2011
    Quote Originally Posted by jtrammel View Post
    X2
    Someone check for me before and said it will match and he saod maybe will need new txv for heat pump
    Jun 2001
    No way a 2012 HP will match a 2001 AC coil. It's never gonna work right until the coil is replaced with the correct model. The 2012 matching coil should have the correct TXV preinstalled.
    Sep 2011
    Hp its tranne 1100 built in 01 coil its aroun 99
    Jun 2001
    My mistake, I thought one was new and other old. Did the system ever work correctly?
    Sep 2011
    Orginal was this conf lennox stright aire hs24-311/1p replaced with 2001 tranne xe1100 twr024c100a5
    Sep 2011
    Can you tell me wich txv will ne correct with tranne twr024c100a5 thx
    Jun 2011
    Seattle WA
    How about saving lots of speculation by giving us the model # of the coil?
    America; first we fight for our freedom,
    then we make laws to take it away.
    -Alfred E Newman
    Virginia
    What txv needs replaced the one on the indoor coil or the one in the heat pump
    Go Trump
    Sep 2011
    Quote Originally Posted by catmanacman View Post
    Yes txv on a coil dont know nimber of a coil its addon and can see. Coil was match to a lennox hs24311/1p its ther any nook where can find what coil can ne there ? And its a txv on a coil.same for srtight air and for hp?
