Results 1 to 9 of 9
    Sep 2012
    Help Me Out Please
    I was recently checking out a 3-ton split system, after hooking up my gauges it appeared it was low on refrigerant(R-22). I had already inspected the air filter, a-coil and duct work to make sure I had good air-flow. The low side displayed 20 degrees(42psi) and the high side displayed 90 degrees(170psi) with an ambient temp of 80 degrees. I added 1 lb of R-22 and the system pressures did not respond at all, what is going on?
    Jun 2006
    Richmond, VA
    It's full of Nitrogen???
    I wish I had a $1.00 for every response I deleted.....
    "Decidedly Superior in a twisted pathetic way".....
    Jerry,
    First off, this isn't a DIY site, so, if you're a tech, you'll need to tell us a little about yourself.
    Filling out your profile page is a good start with that.
    Jan 2011
    Metro Atlanta
    Just add more 22, that always seems to work for me .
    Now to be serious, did you find the leak(s)?
    Do you have a charging chart?
    The opinions expressed by me are not that of my employer.
    insulation modern marvels
    http://www.youtube.com/watch?v=g37riSkyZzM
    Virginia
    Mabey the metering device is not working
    Stuff happens
    Jun 2012
    nampa idaho
    This is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary or ask questions of the OP here. Please apply to the AOPC today, thank you.
    Further infractions may result in loss of posting privileges.
    Oct 2010
    Quote Originally Posted by hkempf View Post
    Only professional members with an * can post in the aop forums
    Last edited by beenthere; 09-26-2012 at 10:38 PM. Reason: Removed quote of Non Pro * Member
    hkempf, this is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise here. Please apply to the AOPC today, thank you.
    Your post has been deleted.
    Jun 2011
    Seattle WA
    May not be an orifice in there. Or the TEV might be busted or out of whack. That would be my first guess going off of the miniscule amount of information we were given.
    America; first we fight for our freedom,
    then we make laws to take it away.
    -Alfred E Newman
