Results 14 to 26 of 42
    Jul 2012
    Western KY
    Fans on? Plastic bag wrapped around cond? Split coils? If fans on and coils clean start pulling charge. Agree with push it on the restriction thing
    Tallahassee, FL
    There must be 50lbs in that thing maybe more. Way overcharged. Once removed she should run longer so you can begin to diagnose it.
    Nov 2005
    Quote Originally Posted by myhvacx View Post
    Attachment 312091
    Reciprocating compressor, the compressor is about 3 months old, the air h is about 3 years old, there's a pic, hope it uploads.. The system may have been overcharged from what i understand about 2 weeks ago..
    Standing high side reads 200psi.
    Unless it is 100° where you are, that 200psi standing points to non-condensables......Just a thought.
    May 2011
    tallahassee,fl
    Overcharged severely if hp trip that quick. Pull some juice.
    Mid Michigan
    Quote Originally Posted by gonefishing View Post
    Exactly what I was thinking.
    Waddya mean don't thaw out the frig with a knive?
    Mar 2009
    Mid-Mo
    I vote for overcharged also but I bet there's another problem lying in wait also. Like maybe someone gassed it up more to keep the suction pressure up.
    Were you the one who changed the compressor?
    Jul 2009
    Columbia, MD
    unhook compressor and let condenser fan run and watch the high side pressure. or verify that both sides are equal pressure. where is the filter drier? i had one restricted so bad not too long ago that the compressor hit 600 psi in 20 seconds
    Nov 2007
    Mississippi
    Pull charge. Change drier. Start over.
    Jul 2009
    Columbia, MD
    and while your at it. weigh what you took out
    Sep 2011
    It was actually way overcharged, so that solved high pressure 5 second run issue..
    Now it seems to be running right but can't lower low side line temp, its about 76degrees coming into the compressor.
    So right now my superheat is around 60, which is very high, I have reached 250psi on the high side while unit is running but the suction does not seem to be affected, remains at around 40psig.
    I think this is what the previous person that worked on it had, so whoever this was just kept on adding freon.
    RIght now my big issue is calibrating it correctly but just don't want to end up overcharging it like the last person did..
    Aug 2012
    North Dakota
    whats your metering device and what charging method are u using
    Sep 2011
    Quote Originally Posted by mechanical'al View Post
    TXV, charging on low side.
    Aug 2012
    North Dakota
    to sub cooling??? what is your sub cooling????
