Results 14 to 26 of 40
    Sep 2012
    Orlando, FL
    Quote Originally Posted by jtrammel View Post
    Most will charge a fee for the testing because it is rather involved, takes time and the testing equipment is very expensive some will discount the testing fee off the invoice if awarded the job. Even if it costs a couple hundred bucks its well worth it when making an hvac investment.
    Took a bit of doing but found a company that would do the testing for a few hundred. No company I called would do it as part of their quote for new AC systems. One said that they do it after a contract is signed and only do the Manual J that way as well, they eye ball for the estimate.
    Sep 2012
    Orlando, FL
    Quote Originally Posted by energy_rater_La View Post
    how much are you willing/able to diy?
    DIY a blower door and duct testing? Thought they both require a bit of specialized equipment?
    Oct 2010
    Quote Originally Posted by scooterfj62 View Post
    No he's talking about improvements to problems with your home if/when any are found at testing. Are you fairly handy? in other words
    south louisiana
    boy this just isn't my week is it?
    diy the air sealing duct sealing per findings of the blower
    door duct testing.
    while allowing the duct sealing to be done by hvac company,
    the blower door will show leakage areas in the house.
    some you address from attic..others from inside the house.
    are you willing to diy the caulking from inside the house?
    personally I find the homeowner does a better job caulking
    as they take the time time to do it well. some areas will
    require caulking twice. as the caulk dries it shrinks so
    a second application is necessary. just isn't cost
    effective to send crew to caulk the second day.
    its hard to price caulking jobs. cheap material but time
    & finesse to properly seal.
    is this something you are willing to do?
    if so, buy by the case, caulk with long life that goes on
    white and dries clear.
    hopefully you'll share your testing results with us.
    best of luck.
    Oct 2010
    I feel like you will see a lot of value in the testing, it's a pretty eye opening experience it was for me tge first time i saw it done. I'm glad you are doing your homework before you make such an investment. Lots of companies don't do man j until they get the job bc it takes time and effort and they don't want to do it then you tell all the other contractors the numbers and someone else gets the job after they have taken the time to evaluate and calculate the size
    Jun 2012
    nampa idaho
    This is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary or ask questions of the OP here. Please apply to the AOPC today, thank you.
    Further infractions may result in loss of posting privileges.
    Jun 2012
    nampa idaho
    Sep 2012
    Orlando, FL
    door duct testing.
    best of luck.
    Will leave the duct sealing to the pros, attic is a little tricky and they have insurance incase of a fall!!! Would be comfortable with the calking and probably take on that job.
    Will absolutely share results and should be interesting to see the difference in the Man J from the original quote and the one from the rater who is doing the blower/duct testing.
    Thanks for all the advice.
    Oct 2010
    Look forward to seeing the results. Keep us posted
    Jul 2001
    Anderson,SC
    Jason,is all you do is stay on this hvac-talk?
    Do you not work any more?
    You give some good info, you are a good hvac tech.
    When are we going to do lunch?
    Stud
    Oct 2010
    I just got time to kill while supervising... Lol. keeps me sharp too
    Oct 2010
    I'll admit I'm kinda addicted
    SW Wisconsin
    resnet.org is another source for an energy rater; we aren't called auditors.
    blower door using subtraction method can measure duct leakage.
    blower door measures house leakage also. different steps..same equipment.
    resnet raters use duct blaster or pressure pans to test
    ductwork you would have to request if you chose to test differently.
    usually houses are pressurized to get leakage amount.
    if you pressurize you can feel the air leaking out of ductwork
    so you know exactly where to seal.
    sealing house leakage means less of the great outdoors to heat and cool
    sealing ducts means all of air you pay to condition comes into the space
    where you live. return should also be tested.
    sealing both leakage areas (house & duct) can change how many
    tons of hvac is required.
    manual J would have to reflect reduced infiltration numbers.
    best of luck.
    I have severe carpal tunnel in my hands & using a tape measuring rooms is difficult. What 50 foot laser ultrasound measuring tools do you or anyone on here recommend?
    I believe everyone ought to use the latest tools & instruments including computer software that will speedup the job of energy rating & load calcs; these days (mostly retired) it's taking me too long to do the job.
    Lot of figuring & paper work involved without good programed software.
    This one any good?
    http://www.calculated.com/prd329/Las...l#.UGSU3mJ-nRQ
