Results 14 to 22 of 22
    Mount Airy, MD
    Quote Originally Posted by theoldman View Post
    The Spyder Tool has a lot of problems. I thought the old systems I worked on were bad. Honeywell is not providing the required resources to this product.
    Don't get me/others started on the lack of resources here....
    Dec 2006
    Boston area
    If your using 3.6 then you should be using the latest spyder tool and you have to put controller in engineering mode to do anything with it. Right click controller and pick engineering mode. There is a good webcast on Buildings Forum on the new spyder tool.
    Jun 2006
    Spyder
    Quote Originally Posted by mechmike2 View Post
    When I read the release notes for the latest Spyder Tool version I seriously considered changing jobs to get away from this product.
    Spyder
    Also take care to know which Rev controller you have, look for a side ways 2 on the sticker next to the part number on the side. If this is there then you may need to flash it back to work with your spyder tool. You will be able to commission it just not load it. I am an old BC network 8000 guy and love the spyders. I don't care what line you work with, there is always room for improvements but the spyders have worked solid for me and the company I work for. I took the class and it shortened the learning curve considerably for me.
    San Diego, CA
    Quote Originally Posted by wherzamizat View Post
    Spyders are awesome controllers. Don't appreciate the attempted humor with the product bashing. Its unprofessional and mean.
    Easy there buddy, that image helped shape what the spyderTool is today. Yes the hardware awesome, but the software took a little while to get there...
    Which one of these versions have you had the joy of dealing with?
    1.16.1
    1.18.4
    2.0.5
    2.0.8
    3.1.1
    3.1.3
    3.1.7
    4.6.0
    4.8.3
    4.8.8
    4.9.1
    5.18
    5.19.6
    5.201
    Council Bluffs, Iowa
    Quote Originally Posted by digo View Post
    1.16.1
    1.18.4
    2.0.5
    2.0.8
    3.1.1
    3.1.3
    3.1.7
    4.6.0
    4.8.3
    4.8.8
    4.9.1
    5.18
    5.19.6
    5.201
    There is a new one coming out in a couple weeks FYI. 5.204
    Mar 2012
    Elkton, MD
    Thanks for the help. I'm going to try the Webcast that you suggested mechmike2.
    Thanks again
    Nov 2012
    Canada
    Noob with Spyder
    Hello,
    I have a Spyder ILC and a niagara AX platform (TES - Trend).
    Normally I don't need spyder tool or other, right?
    I can discover the spyder but that's all, I can't configure or add physical points.
    If I try to add physical point (for example: BacnetDevice -> Config -> AI) I have a fault, cause: Object:Unknown Object.
    FYI, I don't pass the spyder training.
    Nov 2012
    Canada
    Noob with Spyder ILC
    Hello,
