Page 8 of 9 FirstFirst 123456789 LastLast
Results 92 to 104 of 115
  1. #92
    Sep 2012
    Quote Originally Posted by tedkidd View Post
    Take asleep breath, it's all fixable.
    Smaller units w/b ideal.
    We currently can't afford to replace our units again. I mean it's not something that we will have done right away.
  2. #93
    Sep 2012
    A lot of our neighbors around here have oversized systems as well.
  3. #94
    Rochester NY
    Yeah. I have a client in Baltimore, replaced his 120,000/4ton with 60,000/2ton, his energy billis 60% that of his neighbors. Unit dehumidifies so well he sets his stat at 76, lower is too cold.
    Might have some weight for getting your installers to put in smaller units.
  4. #95
    Sep 2012
    Wow that's impressive. I'm surprised that none of the companies around here mentioned smaller units. I live right outside of Atlanta GA so our summers are pretty hot.
  5. #96
    Sep 2012
    When it's not that hot outside our upstairs unit has 5 minute cycles. That's seems VERY short! I don't get why companies around here always install oversized systems. Could it be the location of where I live?
  6. #97
    Sep 2012
    How big was the client's house?
  7. #98
    Rochester NY
    4000 sf "rancher" with a sun room addition - all windows and 4 skylights.
    Heres another thread you might find helpful.
    http://hvac-talk.com/vbb/showthread....is-Down-For-Me
  8. #99
    Virginia
    Quote Originally Posted by 545GAlady View Post
    Can charge more because it's bigger.
    Go Trump
  9. #100
    Sep 2012
    Oh ok. Thanks!
  10. #101
    Sep 2012
    As I'm about to go to sleep, what size do you think will be best for the main level? I was guessing a 2.5 ton and maybe a 60,000 BTU furnace. That thread you linked seemed very helpful.
  11. #102
    Rochester NY
    Quote Originally Posted by catmanacman View Post
    .and homeowners want their equipment to NOT run, and they want to use crazy setback, expecting 4 minute recovery, there are a litany of corrupting influences leading to bad design decisions.
    Hvac guys can't afford to educate homeowners (or even their salespeople), or put up with non revenue generating complaints on really hot days. It's feast then famine, hay needs to be made while the sun shines. The homeowner bears ultimate responsibility for shortcuts when low price is king and diagnostics and design are cut out of the process.
    Spread the word and maybe things can change.
  12. #103
    Sep 2012
    We never have a problem with humidity. Humidity is never high in our house.
  13. #104
    Rochester NY
    What temperature settings do you keep the house at?
