Thread: ecap coil
    Sep 2011
    ecap coil
    do a evap coil with expansion valve from lennox hs24-311-1p will work with treen xe1000 twr024c100a5 thx
    It will work.
    Sep 2011
    It will work.
    Thank you accaly i got this setup now lennox stright air hs24 + gas furnace like to install this trane hp and dual fuel thermostat to use in a winter as heat in not cold days its something ele what i need ? thx
    May need a new TXV, one for heat pumps.
    Sep 2011
    can you tell me which txv need conrtactor replac e out unit now cool works ok he said txv is bad in heat mode its freezing a small line betwen txv on a coil and out unit ?
