    Oct 2006
    Question
    I have a uniques building that requires a 3 Ton SCAV unit to be hung in the ceiling. I am having trouble locating a unit to replace the failed existing Fedders. Fedders product line does not show a SCAV unit. This unit is 208/230 single phase, cooling only, with supply/ return duct connections and condenser in/ out connections. This is obviously an air to air unit. R-22 or R-410. Do you have any suggestions. Measurments are approximately 42" w x 46" d x 24" h. Thank You for your help.
    Apr 2004
    RCI typhoon if you want a storm....Gob to United Cool-aire or Skil-Aire....... Typhoon stuff is complete junk
    Brooklyn, NY Occupation: HVAC Service Contractor
    Try the link below. Skymark Air Conditioning. Decent units. They match up well with replacing Fedders units. There is always the Carrier Roomtop 50AH036. I replaced about 50 old Fedders units with them. Bottom access to fans can be a problem with ceiling design.
    http://www.skymarkinternational.com/...i=8&detailID=7
    Oct 2008
    if your looking to replace fedders check with united refrigeration they sell the fedders/addison line
