Results 1 to 13 of 14
    Jan 2010
    PILOT VALVE REBUILD KIT?
    Hi guys. I have tried Googling my butt off, looking for a rebuild kit for a Honeywell gas pilot valve, model # VR3800A 3153, with no luck. Any suggestions, or known links i can check out?
    Oct 2010
    Anderson SC
    Quote Originally Posted by 903ASP View Post
    What are you trying to rebuild on it?
    Jan 2010
    Quote Originally Posted by jtrammel View Post
    Not sure. I only know that all worked on the floor, before i raised it up to the ceiling. After re-connecting all, turning on power, and gas, the pilot worked, turned up thermo, and after a minute or so, the fan kicked on, but not the burners. I checked voltage to valve, from transformer, and it showed 24 v, so if i had voltage, and fan kicked on, i assume something mechanical malfunctioned in valve?
    Oct 2010
    Anderson SC
    I would call a service tech out to see why the burners don't light, could be a safety function. What type of furnace is it model number and brand?
    Jan 2010
    Thanks for the advice JT, but i'm capable of doing it myself. 40 yrs., as a millwright/semi-electrician/machine install repair, etc, etc. Will be breaking down the valve, whether or not i can find a rebuild kit, to see if i can find/fix/ or replace parts. The heater is a Dayton 3E232D, input 200k/output 160k. I have just finished converting orifices in all 8 burners, pilot burner, and spring in valve, from NG to LPG. What i didn't state in the beginning, was that i bought heater used, and it was set outside, with gas pipe facing up, and top end was open to the weather. There was a lot of wet sludge in input end of valve, and i'm thinking some of it may be still inside, clogging something up. I may luck out, and be able to clean inside, and free problem area up? But i like to look ahead, therefore the request for info on purchasing a rebuild kit. A lot cheaper than purchasing a new valve. Would pick up a used valve, if i could find one
    Jun 2011
    Seattle WA
    Betcha your manifold pressure is all kinds of messed up and you're going to "rebuild" the gas valve only to be back at square 1.
    America; first we fight for our freedom,
    then we make laws to take it away.
    -Alfred E Newman
    Jan 2010
    Quote Originally Posted by LibertyTree View Post
    And what would cause the manifold pressure to be "all messed up", if it worked fine on the garage floor yesterday, but wouldn't when i raised it up to the ceiling today????
    Lancaster PA
    No rebuild kits for valves.
    Sorry, this is not a DIY site. Please read our site rules, thank you.
    Jul 2010
    nebraska
    Just to keep you safe...gas valves do NOT get rebuilt. It's flat out not allowed.
    Quote Originally Posted by martyinlincoln View Post
    No offense, but, if you were capable of making the repair, then you'd have made it already.
    Call a professional before something gets blown up.
    Cincinnati, Oh
    although it may make economic sense to make a rebuild kit, it doesn't make sense in the realm of safety.
    Your working with a device that creates a controlled explosion inside a vestibule.
    Imagine if an internal spring slips, and blows gas constantly, then 20 minutes later it tries to fire.
    It's not worth the risk, and there are an extremely small portion of our industry that would even attempt what your suggesting.
    "Just get it done son."
    Dad adjusted
    Aug 2001
    Pavilion, NY
    I think the next time we hear about this will be on the local news.
    Jan 2010
    Well, i thank you all for your concern,advice, and of course the couple of "JABS". As you stated Beenthere, it is not a DIY site, so i'll move on. ADIOS
