Results 1 to 6 of 6
09-22-2012, 04:48 PM #1
New Guest
- Aug 2012
- 3
Install help - Ecobee Smart Si on a fan coil system
Hi,
I bought an Eco Bee Smart Si Thermostat. The system is an AE -Air fan coil running on the building's cold and hot water loops. The only control I have in the system is opening and closing the actuator vales for the hot or cold loops and running the fan. See the system: http://www.ae-air.com/products/ahbc.asp
The old thermostat had 5 wires. R/C/W/Y/G, I wired them accordingly to the smart si thermostat. See the wiring digram of how things are wired now that I drew.
http://www.circuitlab.com/circuit/44...eating-system/
The problem I am having is I can not get the system work work properly. Do I call this a heat pump in the thermostat settings? If I do then I can get the cold system working, but not the hot. If I call it a furnance I can get the hot system working but not the cold. Have I made a mistake on the wiring, or is there a setting in the thermostat that is wrong? It seems to me this should be a very simple system. There are two valves and a fan, nothing more.
Any help is appreciated in setting this up.
09-22-2012, 05:20 PM #2
No DIY on this site. Call a pro to get it set up properly. Dependent on what type of control voltage you are working with the ecobee stat may not work for that application.
09-22-2012, 05:30 PM #3
New Guest
- Aug 2012
- 3
The Transformer is 24V. If it makes you feel better the install was done by my brother who is a tin basher. He just doesn't know the product very well and he was just in town for an hour.
09-22-2012, 05:36 PM #4
A tech should be able to get it going if its 24v. We aren't allowed to get into specifics with Homeowners on this site
09-22-2012, 05:57 PM #5
You don't have the configuration settings correct. Keep reading them.
10-25-2012, 01:14 AM #6
I've started an album of chart screenshots from my Ecobee portal. Look what can be learned by tracking how a home and it's equipment interact with each other and the environment.
This thing tracks indoor, outdoor temps, run time, and RH.
Each vertical red line represents up to 5 minutes of run time.
Green line is indoor temp
Black is outdoor temp.
Dotted red is set temp
Really interesting to see cycle time and impact.
