Results 1 to 12 of 12
    Aug 2008
    Finally broke down and purchased 2 Honeywell 4" and 5" Return Grille Filters
    Both were <$ but I'm hoping they make up in convince and better air flow than those 1" pleats I've been using.
    Tallahassee, FL
    They certainly do. Typically they outperform 1" filters even when visibly dirty.
    Jun 2001
    And they last 4 times as long..
    south louisiana
    you could have just gotten a 4" media filter with a 1" lip to
    fit into existing return filter grill. just have to shop a bit for them.
    Jun 2001
    Quote Originally Posted by energy_rater_La View Post
    I looked into those but it only takes a few filter changes to pay for the larger return grill. The 1" lip/4" filters are expensive when you do find them.
    Aug 2008
    Got that right
    Quote Originally Posted by 54regcab View Post
    #majorhvacinvestment
    south louisiana
    oh.
    I bought a case from hvac supply.
    not a bad price that way. about the cost of
    3 individual 4" filters and 5 per case.
    Aug 2012
    Additional infractions may result in loss of posting privileges.
    Mar 2009
    Mount Holly, NC
    The TRUE highest cost system is the system not installed properly...
    Find a HVAC-Talk Contractor by clicking here
    Do you go to a boat repairman with a sinking boat, and tell him to put in a bigger motor when he tells you to fix the holes?
    I am yourmrfixit
    south louisiana
    that link is for the type of media filter that requires the return air filter grill be replaced.
    not the one that retrofits into existing rafg.
    Tallahassee, FL
    No its the correct link.
    newstudent
