Results 1 to 8 of 8
    Sep 2012
    Cape Coral,Fla
    Quick Question!!!!!
    I ran into a Eurocave wine chiller today. Inside of the chiller on the back panel is icing up...Everything checks out fine....What do I look for?
    Oct 2011
    Chicagoland Area
    If everything checks out fine, then I guess you're good to go...
    British Columbia, Canada
    Appliance repair. Under "A" in the yellow pages I would guess.
    Oct 2011
    Chicagoland Area
    That makes less sense than the OP
    May 2011
    Oklahoma
    Quote Originally Posted by mrjohn12 View Post
    Is there any refrigerator which is able to freeze stuffs without power ?
    I mean It can get power for one time and its at the first .
    Then it will run by recycling the power of heat .
    Or it will be able to run by low power .
    Refrigerators are not meant to be used as freezers.
    There is no perpetual motion freezer.
    You mean an absorption system?
    RV fridges use electricity to power a heater element or burn propane as a heat source to heat the chemicals that gets the refrigerating process underway by means of evaporation and condensation.
    IF that is what you meant. Maybe you are looking for a cordless sixpack cooler, it's kinda hard to determine...
    Sent from my SGH-I747M using Tapatalk 2
    What is that, a "Speller Cell"?:what:
    Oct 2011
    Chicagoland Area
    Quote Originally Posted by matt1124 View Post
    mrjohn12 deleted his post but it lives on in your quote
