Results 1 to 8 of 8
    Reach in freezer is cooling like a refrigerator
    Working on a shipboard galley reach in freezer, it is a 134a system with 18oz of refrigerant. The system is not over or under charged but the compressor runs constantly and the temp inside the box will not go below 44 degrees. I usually work on larger freezers and chillers but this small freezer is giving me the blues any help or ideas? The TXV is non adjustable.
    From here, I can take your word for the fact that it is broken.
    Without some technical data and some operating data, that's where it ends.
    Southeastern Pa
    Something is afoot....
    California
    Quote Originally Posted by sweetjamesjoness View Post
    I would start by taking your large freezer and chiller knowledge and apply it to this small freezer.
    Model numbers, pressures, temperatures, amp draws...
    you know...kinda like troubleshooting.
    44 degrees ?
    Thats not even enough to cool a refrig
    Just plumb it to cool the cabin ....
    Oct 2011
    Chicagoland Area
    Make a great wine cooler
    Local 597 Service Fitter
    Metal Trade Journeyman
    PAY ME NOW OR PAY ME LATER
    It was working when I left...
    WWFD
    British Columbia, Canada
    Check amp draw against RLA if it has a silver door and check both pressures if it has a white door. Or is it the other way around?
    If it's a different color door than that then more info is needed.
