Results 1 to 12 of 12
Thread: Voyager Test Mode
09-20-2012, 07:40 PM #1
- Jul 2008
- 30
Voyager Test Mode
I have another tech call me and he said that a unit is skipping the economizer in test mode. I thought I remember reading about this problem before but could not find it even looked in the mess they call comfortsite.
09-20-2012, 11:18 PM #2
the controls will skip what it doesn't have or isn't communicating to. the economizers do move pretty slow...maybe its not skipping it. maybe the motor is bad. stop using the 'jumper' version of moving around 'test mode'. start using the resistance test method...life is a lot simpler.
The weak aren't destroyed by the strong.
The weak are destroyed by the under-estimated.
I know a famous song that ends in 'my nose'. The artist is dead. Know who?
09-21-2012, 08:15 AM #3[Avatar photo from a Florida training accident. Everyone walked away.]
2 Tim 3:16-17
RSES Certificate Member
AOP Forum Rules:
09-21-2012, 09:43 AM #4
I built a box mostly because of trouble with economizer test mode.
My material list:
-really nice jumper wire cut in half
-2x4 box with cover
-on off toggle switch
-0-50 potentiometer with knob
Works great the pot scale is a little broad but it's fine. I just set it with my meter to the desires resistance, hook it on, flip the toggle switch when I'm ready.
09-21-2012, 09:50 AM #5
Works good on service checks too because you get straight to the desired function.
09-21-2012, 11:54 AM #6
I like it. I'm sure I have an old pot in my junk box.
09-22-2012, 07:37 AM #7
I built one with resistors and a six position rotary switch. I can jump straight to desired mode. I used a pot before, but it was a little tough to get it dialed in just right. I also was using 0-50 ohm pot.
09-22-2012, 12:14 PM #8[Avatar photo from a Florida training accident. Everyone walked away.]
2 Tim 3:16-17
AOP Forum Rules:
09-22-2012, 12:17 PM #9The weak aren't destroyed by the strong.
09-22-2012, 12:18 PM #10The weak aren't destroyed by the strong.
09-22-2012, 01:01 PM #11The weak aren't destroyed by the strong.
09-22-2012, 09:44 PM #12
- Mar 2011
- North Carolina Piedmont Area
- 291
have had good luck with a variable resistance decade box made by IET RS-200
