Results 1 to 4 of 4
    Apr 2010
    Gas Equipment venting to an exterior metal chimney
    I am looking for advice for venting a boiler and wh into an outside chimney 40 Ft high
    the boiler is fan assisted 233 MBh and wh is Nat draft 75.1 MBH , total gas load 308 MBH
    the outside design temp is 12 deg f
    the chimney is not specified yet . a 7" interrnal type B vents works inside, but owner doesn't want to lose space.
    i was going to spec a stainless steel chimney for outside
    the only tables i can find in NFPA 54 are for exterior masonry chimneys and the and i cannot satisfy the minimum gas input in table for a 40 ft high chimney
    You need some kind of liner or you will condense the gases from both units. B vent down the chimney will be great.
    Sent from my HTC VLE_U using Tapatalk 2
    Apr 2010
    ok
    what about using a class A dbl wall ext chimney w/o a liner
    Jul 2009
    Columbia, MD
    that piping job is gonna be expensive!
