Results 1 to 13 of 19
09-20-2012, 03:35 PM #1
New Guest
- Sep 2012
- 2
sizing question for btu on new furnace
Hey Everyone,
I got a couple quotes and different opinions on sizing for new furnaces. I am replacing 2x25 year old 90,000 btu lennox furnaces.
I am looking at 2 95% efficient furnaces with ECM motors.
My house has the upstairs which is 850 sq ft, the main is 950 sq ft
one furnace runs the upstairs the other runs the main floor and 2 vents in the basement. (not need much heat down there)
one quote said a armstrong air 90,000 for main floor and a 70,000 for upper.
the other quote said 2x 60,000 goodman furnaces. and told me a 90,000 is way to much for the size of the house.
Can anyone chime in and let me know what they feel would be good sizing for the 95% efficiency furnaces for the sizes of my house.
Cheers,
djrocketodd
09-20-2012, 04:01 PM #2
90,000 sounds grossly over sized for a house of your size.
09-20-2012, 04:12 PM #3
180,000 on 1800 sqft a bit much. Resizing both will probably require more then just replacing the units. Should be able to handle that space with much less but it's really not that easy to get there from here.
09-20-2012, 04:25 PM #4
Professional Member*
- Apr 2006
- Barrie Ontario
- 208
Do you live in Alaska with paper walls. I've done 1800 sq feet with one 60,000 furnace in northern central Ontario do you self a favor and get a heat loss calc done on your house
09-20-2012, 04:45 PM #5
Where is this house located. ???
Sounds very very over sized to me
09-20-2012, 05:10 PM #6
In our cold climate for a house of that size we would have 1 70,000 BTU furnace typical construction. So I can't imagine meeting anywhere near what those dealers are suggesting.
Find a good dealer who will do a heat loss calculation.
Sent from my HTC VLE_U using Tapatalk 2
09-20-2012, 05:22 PM #7
New Guest
- Sep 2012
- 2
I live in Calgary Alberta, so it does get a little cold and the house was built in 1986. I want to keep the split of main and upstairs separate since there is no zoning in the house. Thanks for the input, i felt 90k was a bit overkill as well.
09-20-2012, 05:32 PM #8
2 - 40,000 btu units sound just about right.
09-20-2012, 06:12 PM #9
- Jun 2001
- Moore, Oklahoma
- 2,674
09-20-2012, 06:28 PM #10
- Jul 2010
- nebraska
- 1,231
Might even want to go to the next level and get a pair of 2 stage 40-45,000 furnaces. There's not much cost difference and quite a bit more comfort. The upstairs unit will probably never go to high fire.
09-20-2012, 07:58 PM #11
09-20-2012, 10:01 PM #12
- Nov 2004
- SW FL
- 5,354
09-20-2012, 10:33 PM #13Which makes more sense to you?
