Results 1 to 7 of 7
    Sep 2012
    New AC & Furnance in Northern VA
    Hello everyone,
    I own an approximately 1600 sq ft townhouse that is 17 years old. The HVAC system is original to the home (Comfort Maker). I have gotten bids from 3 independent companies. With all the options, I could really use some input regading which system is best.
    Company A: 3 different proposed setups. Each one include replacing the condenser lines.
    Carrier
    58STA090-1-14
    24ABB336
    CNPVP3617
    Carrier
    58PHA070
    24ABB336
    CNPVP3717
    Carrier
    58CVA090-1-16
    24ACC636
    CNPVP3717
    Company B: They proposed flushing the condenser lines.
    Amana
    AMH8180
    ASX13036
    CAPF03617
    Bryant
    315AAV048090
    126BNA036
    CNPVP03617
    Company C: They quoted me the AC and furnace separately. I have a call into them regarding the condenser lines.
    Bryant
    113ANW03600
    matching Bryant coil
    Bryant
    126ANW03600
    Bryant
    310AAV036070
    Bryant
    315AAV036070
    Thank you for your input!
    Dec 2010
    What we call a townhouse is a series of attached 2 story homes with a basement.
    With out knowing what your home looks like I can't comment on the sizing of the equipment.
    I, at this point, can only recommend going with a variable-speed blower, the E-Z flex filter (standard with the Bryant equipment) and the tin plated coil.
    I would be curious if any of the contractors mentioned the last two items?
    Sep 2012
    Quote Originally Posted by George2 View Post
    My townhouse pretty much fits that description, except it's a 3 story home. The basement is at ground level and it's finished.
    None of the contractors mentioned the filter or the tin plated coil.
    Rochester NY
    1600 sf, no load to the left or right? I'll comment on size:
    TOO BIG!!!
    Does anybody perform energy audits in your area?
    If you get one they'll perform a blower door air leakage test. This will help you understand how many invisible windows are open 24/7. It will also help you understand how many of them can easily be closed, which will allow for smaller equipment. Equipment that, besides being less expensive to purchase, will provide quieter, more even comfort and MUCH lower bills. The audit will provide a load calculation of the house.
    Load calc's without blower door tests are like getting a custom suit made, but only measuring from the waist down and guessing on the coat. Infiltration is where humidity comes from, and commonly represents 10-70% of load. Want to guess if it's 10% or 70% for your home? If it's 10%, you really want to pay for 50% more AC because they're "playing it safe" on your dime? If it's 70%, don't you want to do something about it? (If not, don't later blame the equipment because it doesn't keep you comfortable.)
    Brand of equipment doesn't matter too much. Correct sizing per ACCA manual j and proper installation is what matters, so it's the contractor you want to trust not so much the brand of equipment they use
    I Agree with tedkidd on the blower door test, it will do you no good to install a high efficiency system on a leaky/undersized duct system/house.
    Dec 2010
    Quote Originally Posted by nova43 View Post
    I would have bet $1,000 that no one mentions those items I listed. It's really a shame.
    I totally agree, now that I know ur sq. ft., with everyone here, that the equipment is TOO big. If ur windows face N/S, I would recommend a 2 ton A/C.
    This doesn't shock me too much when the contractors don't even mention basic good installation practices. It's all about a low price to get the job. It's just poor salesmanship IMHO.
    Note: I'm assuming that you have roughly 535 sq. ft. per floor? As I stated, 2 floors plus a basement, which ur calling a 3 story townhouse. I normally don't consider the basement a "floor" in the normal sense but, if I recall correctly, realtors refer to townhomes in that way (for some reason).
