Results 14 to 20 of 20
    One pipe system going thru roof with 2'' pvc. No obstructions at all. Taking air from crawl space. Talked to tech at goodman and he said that the switch trips at 200f. Put a temp probe near the switch and it tripped at 197f after running for 10 minutes. Unit was converted to propane.
    Jan 2011
    Cincinnati Ohio
    Couple of questions: how big is the furnace? How big is the crawl? Is the crawl sealed up tight or vented to the outside?
    Sent from my Nexus 7 using Tapatalk 2
    70 thou btu. Crawl space is 30 by 40 feet 32 inches high and vented.
    Jul 2010
    nebraska
    Check the level of the furnace. Kind of sounds like your secondary exchanger is building up some water after several minutes of run time.
    Thanks, I do believe that the other contractors did some jacking on the house.
    Want to thank martyinlincoln for the info on the leveling of the furnace. Did the trick. You rock!!!!!!
    Jan 2011
    Cincinnati Ohio
    Glad you got it knocked out.
