Results 66 to 78 of 161
Thread: pulling a vacuum
10-03-2007, 11:41 PM #66
- Sep 2007
- 28
My son said that he sw a demonstration using copper tubing that blew away the hose performance. I agree to use analogue not digital micron gauge and u need to learn how to use the gauge. experiment with it. it must hold its reading. not just momentarily or for 2 minutes. it has to hoooold to be a good reading. leak testing and leak locating are entirely different processes. boy am i going on and on. sorry. J
10-03-2007, 11:57 PM #67
- Apr 2007
- 6,286
10-25-2007, 10:55 AM #68
- Dec 2006
- s.w FL
- 19
Just wondering having just purchased new digital gauges, does pulling a vacuum with the digital gauges hurt them any, should I stick with the old ones or is it okay. Just don't want to screw up 700.00 tool in the 1st month of having them.
10-25-2007, 07:50 PM #69
Member
- Oct 2006
- Emerald Coast, FL 30.1N 85.8W
- 681
I use a micron guage, but nobody else does....lol
I mostly use the digital YJ 69080 with SS flexible hoses. I prefer either the analog or guages that show digital incremental vacuums(like from 1000 microns to 500 microns). I don't like digital guages that show 1 to 10 micron incremental vacuums because of the wild fluctuations you get in the field.
10-25-2007, 07:57 PM #70
Member
- Oct 2006
- 681
Must have guage perpendicular to the vacuum
10-31-2007, 08:47 PM #71
- Dec 2005
- 59
90% Don,t use a micron Gage.As a good Teah do not do what bad people because there not techs.THEY ARE JUST PEOPLE WIHT A JOB!
10-31-2007, 09:14 PM #72
Member
- Oct 2006
- 681
As both a mechanical engineer & HVACR technician, I've been on the front lines of the HVACR industry from the top corporations in the world to the abyss of residential installations -- all I can say is the industry has a long way to go.
There is a huge difference between a true technician & professional and, from my experience, very few people do things by the book in the real world.
10-31-2007, 09:54 PM #73
Professional Member*
- Oct 2007
- Richmond, VA
- 334
I went to a class for Ultra Low Temperature and the Manufacturer putting on the class recommended using copper instead of hoses. I have tested both and can say, without a doubt, that when using copper, the system pulled down much faster and held better during the blankoff test. If I'm on a critical system, I will use copper but under normal circumstances, hoses work fine. Just my two cents.
Bill
10-31-2007, 10:02 PM #74
- Oct 2007
- Richmond, VA
- 334
I use the Robinair analog style Micron Gauge and have used the Ritchie Digital. Guess I'm "old school" because I prefer the analog to the digital. I just sold the digital to a newby cause it was just collecting dust and taking up space in my truck. Spend the extra money and invest in a good one. You won't be sorry.
Bill
10-31-2007, 10:05 PM #75
- Oct 2007
- Richmond, VA
- 334
03-23-2010, 11:02 PM #76
New Guest
- Mar 2010
- 2
Hey Folks, very refreshing to hear from techs in the trade. Just got my review from DA Boss, they said great service tech, best we ever had, but your new construction numbers are suffering, you go by the book to much. Been here seven months, Hmmm I ask where is your vacuum pump, recovery unit and rec. tanks? I guess we could use mine :+) Elctricians should not manage a HVAC company. Glad to see I am not the only one trying to do the proper thing. You guys got any pictures on the copper set up for the MC guage? Keep it cool.
03-23-2010, 11:09 PM #77
New Guest
- Mar 2010
- 2
My challenge is getting the Bosses onboard with a solid procedure. Trane says 500 microns is good once reached no matter the time it's good to go, Good says pull down for 15 minutes. I have a JB 7cfm and have yet to use the copper trick, I like it! Keep searching and learning.
03-24-2010, 05:04 AM #78
- Oct 2009
- 52
Hi PinoyCano:
I think you have just outlined the problem here. While most of us need to use a micron gauge to ensure everything is as it should be, a lot actually do not. Why? Because there are no standards. Not in how they are used and not in the gauges itself.
which is attached to my old Welch Duo-Seal 2-Stage belt driven vacuum pump (Model 1400). It can still pull down to about 800-900 microns. Only problem is it needs a new shaft seal
