Page 10 of 13 FirstFirst ... 345678910111213 LastLast
Results 118 to 130 of 162
  1. #118
    Dec 2009
    maroon lazyboy
    Quote Originally Posted by Vettgetsmwet04 View Post
    nothin wrong with doin that, some just like the tree because it has valves built in.
    i use the jb 142n pump with 2- 3/8" ports and a 1/4" port built in.
    i use 3/8" to 1/4" yellow jacket hoses and 2 appion core tools on the service ports.
    i dont use a tree, i use the setup that came with the pump, it works just fine, just make sure its leak free.
    I have a Robinaire pump with the 3/8" flare now... Also I have access to a JB 7cfm.... And it is set up just like yours.
  2. #119
    In a boiler room
    Same setup I use.
    How do you connect your micron gauge to the CRT? With a short hose? I have had problems with the hose collapsing under vacuum and also I suspect it permeates badly. I can't get my Bluvac to hold steady, it always has a slight rise, around .1 micron per second. Never noticed a problem with my Thermal!
  3. #120
    louisville, ky
    i use the side port on the appion if its possible.
    some units will not let this happen due to tight spots, sometimes i cant get both core removers on.
    worst case i will put the micron gauge on the 1/4" port on the vaccum tree, i like it away from the vaccum, but it will go there before i add another hose to the equation, i try to eliminate all the connections i can.
  4. #121
    In a boiler room
    Does your Micron gauge have a female fitting or do you use a hose to your crt?
  5. #122
    louisville, ky
    yes, i use the jb dv22, its female so it screws right onto the valve core.
    i got the blu vac at the top of my list, it looks like it has a male fitting now that i look at it, is that correct?
    if so then u have no option but to use a short vacuum rated hose to connect it.
  6. #123
    In a boiler room
    Yes, I wish it had a female fitting.
    I'm thinking about using a female to female flare swivel to connect it. That would eliminate the need for a hose.
  7. #124
    louisville, ky
    Dec 2009
    maroon lazyboy
    surely you could get just a valve that had a swivel on each end? I have no idea where to look but it would be nice.
  9. #126
    Apr 2008
    Central CA
    Quote Originally Posted by knave View Post
    JB D10244 Deep vacuum 1/4 sae swivel coupler
    Just picked up two myself, the rubber gasket is smaller then normal though so it looks like it might have to be babied.
    If using for vacuum i reccomend some Nylog on the gaskets.
  10. #127
    Nov 2007
    Just watched the video for Nylog. Looks like some good stuff.
  11. #128
    This is a Appion core tool that I soldered a 1/4" female QC on.
  12. #129
    Jul 2000
    NW IL.
    You soldered a Quick Coupler onto an Appion Core Tool???? Need a closeup photo of that.
    Aircraft Mechanical Accessories Technician. The Air Force changed the job title to Air Craft Environmental Systems Technician. But I've decided I'll always be a Mech Acc.
  13. #130
