Results 14 to 15 of 15
    Dec 2008
    Ontario Canada
    The control can be adjusted to deg F in the install parameters you hold down one of the buttons the one with the clock I think and it switches all temps from C to F. It's in the manual
    Oct 2012
    actualy if you use an external aquastat then you dont need a mixing valve. The pump will kick of at the set temp. If it has an external aquastat make sure its set to the disired temp
