Results 1 to 7 of 7
    Sep 2012
    Columbus, Ohio
    SIT 820 Nova mV Gas Valves -- Models?
    Good morning,
    Can someone point me to reference material that will show/describe/list the differences between different SIT 820 Nova mV series gas valves?
    For example, there are 0.820.633, 0.820.634, 0.820.652, and so on. I've not found anything that explains the differences. I've checked the manufacturer's website and only found general information on the series.
    Thanks,
    Jason
    Nov 2009
    Simcoe, ON Canada
    I've tried to find out this also. No-one will tell use the specs of the different models. Best bet is to make your own cross reference chart. Majestic and Napoleon and Regency use the same valves in some of their models.
    S.E. Pa
    SIT publishes this info on a valve spec sheet. It denotes various dropout rates at specific milliamp draws. Contact SIT Controls USA
    Nov 2009
    Simcoe, ON Canada
    Thanks, I will check that out.
    Sep 2012
    Columbus, Ohio
    Quote Originally Posted by hearthman View Post
    I tried, but I didn't have good contact info. I couldn't ever get a call or email back from anyone I tried. I did a lot of googling and finally found a guide that gave all the specifications for each model of a series.
    Jun 2011
    Fresno, CA
    hook up the specs lakee911, I tried to get more info as well but came up short I have however got some info from a dexen gas valve company they were pretty cool about emailing info, just trying to compile as much info on gas valve trouble shooting as possible. Have a cool one.
    Nov 2009
    Simcoe, ON Canada
    Found a document that gives some specs. PM me if you would like me to email you.
