Results 1 to 7 of 7
Thread: Trane Purge
    philadelphia
    Trane Purge
    I am trying to track down the gasket number for the filter canister on the original style purifier purge. ( Filter is vertical and part of the pot) any help much appreciated.
    ottawa canada
    GKT 1909 rings a bell , but check with Trane parts first .
    Scratch that thats a oil filter gasket for a FLR 239 oil cooler .
    Try GKT1985
    Whooo Hooo spring at last , time to get the toys out ........vrrrroooooom !!!!
    Indiana
    I believe it it is a GKT01984
    N.E. IA
    One word of caution ---- Is this chiller still on R-11 or has it been converted to R-123? The original gasket WILL NOT stand up to R-123.!!!
    "Wheel" mechanics work on "Wheel" chillers
    philadelphia
    Thanks all, this double ender is still R-11. I will try those numbers tomorrow and let you know, thanks again
    GKT01984 is for the R11 purges.
    The weak aren't destroyed by the strong.
    The weak are destroyed by the under-estimated.
    MEXICO
    GASKET; .12 X 8.31 OD R123 COMPATIBLE
