Page 3 of 3 FirstFirst 123
Results 27 to 39 of 39
  1. #27
    Rochester NY
    Fantastic, standing behind the work. Sounds like they'll put in a smaller pump if that's determined to be a good idea. And don't feel bad, their pain in this will make future work better, protecting future consumers.
    There really is no such thing as an exact manual J. And a problem when performing a load calc after the fact is it's pretty hard to avoid bias of making the J fit the install.
    See if you can get them to bring a blower door. If not, ask for the J analysis on both very loose and very tight homes so you have a range.
    Brand isn't the cause of this problem. Carrier generally tends to be the technology leader (everybody's got communicating now). One notable exception I'm aware of, the Rheem mod was revolutionary (everybody's got modulating now).
  2. #28
    Jun 2012
    What is a blower door and why am I asking for it? I talked to them about square footage and actually a 2 tonay not be enough on super hit days as he indicated we were on the border and it would be best to be a litte too big than not big enough...Someone suggested 2 stage unit...What is the justification for asking for that? Also, someone mentioned my paying a pretty penny for what I got ...We paid $6000 and all other estimates for a Carrier system like this were higher...
  3. #29
    Rochester NY
    Hacks.
    Theyve not done a blower door, so they're completely guessing infiltration, and no manual j, so guessing solar gain and thermal load. How do they know 2 ton is to small. That's a complete guess that anicdotal evidence suggests is incorrect. Your logging appears not to have any long cycles.
    Hacks. Little too big is better is a hack comment. You really gonna have a coronary in the unlikely event the unit is little too small and the house backslides to 77 one day a year? I don't think so. If its 100, 77 will feel pretty good. Little to small one day a year is way better than way to big most of the time.
    I've got a client with a 4000 sf rancher in Baltimore. 2 ton heat pump. Can't believe the comfort. House had a 4 ton.
    Of they don't know what a blower door is, ask them if they know what a hack is.
  4. #30
    Jun 2012
    Hee! Hee! I imagine my Tues morning shall be amusing...Think I am going to have to print all of the suggestions and comments here so I don't get. Ur so freakin confused!
  5. #31
    Rochester NY
    Good luck. This is where you get value going with a reputable company, they trip over themselves to make things right. And you have plenty of information to avoid a brush off. Please don't forget to let us know how it goes.
    Blower door - measured building leakage
    Load calc. Including measured building leakage, or alternatively show load range assumptions from loose to very tight.
    External static pressure - how well the equipment matches your duct work. Oversized to duct is colossal fail, smaller required.
    Duct leakage - if ducts are leaking to or from outdoors, pressure imbalance brings in a LOT of hot wet air. This is worsened by high ESP.
    And remember, you can usually improve comfort by improving the house. If the unit seems too small, a little air or duct sealing may well fix that. Throwing a bigger unit at a problem often causes more trouble than it cures as you are experiencing, and home repairs can make it worse rather than better.
  6. #32
    Jun 2009
    Jesup GA.
  7. #33
    Cool_Air
  8. #34
    Jun 2012
    Who is a non AOP member? I was the consumer only responding to questions asked by your posters...
  9. #35
    Quote Originally Posted by CoastalWGSD View Post
    Look in JP's post. See the name in bold print "cool_air". Thats who he was talking to.
  10. #36
    Jun 2012
    Oh, OK...Never saw cool air's post...Thanks to everyone that has replied...It has been very helpful info topped with just enough sarcasm to make learning this more enjoyable in light of our situation...I will certainly provide an update after our meeting on Tuesday!
  11. #37
    Jun 2012
    Hey all...Sorry for not getting back out to you guys, but it has been crazy here...The company actually sent out another top tech and he went through the entire system, duct work and all (they didn't install ductwork) and he stated that everything was running perfectly and that the last adjustment they made on the air handler was a perfect adjustment and that this system was running perfectly. He did explain that the old air handler/coils had smaller coils and that my perception of humidity prior to their adjustment on the air handler could be due to the air running over larger coils. End result, they stated that if I still wasn't satisfied, they would pull the system and refund my money in full.
    I really feel like this company went above and beyond and was super responsive. I did call another company because everyone (not just here, but other folks too) was saying I paid too much for this system. I called two more companies (that I hadn't called before) and got an estimate from each one with the EXACT same model numbers, etc and they were within $100-200 of what I paid. Needless to say, I just moved the thermostat to where I was comfortable and got over it needing to be on 72.
    Thanks SO much for your input and explanations! I feel like I have learned a lot and can even better represent my clients in Real Estate! Great forum!
  12. #38
    Oct 2006
    Baltimore
    just a thought, but i read in one of your ealier posts that you had brought in another thermostat that was reading higher temps. it's possible that your stat isn't reading right and is just a few degrees off. this would cause your system to shut off before it had actually reached the temp that you want. depending on what stat you have this can be adjusted in the program.
  13. #39
    Jun 2012
    We just had a fireplace remote that showed the room temperature...It wasn't actually a thermostat for the system...It seems that if I set it at 70, it cools and dehumidifies like my old system did at 72
Tags for this Thread
