Results 1 to 13 of 18
    May 2012
    Upper Michigan
    Challenger/boiler buddy.
    Did this last week, its sort of a cluster fu*ck but I ran short on room.
    Took these out
    Western MA.
    Looks good,what did you remove,a warm air furnace and a boiler?
    I love overtime I just hate working for it.
    May 2012
    Upper Michigan
    They had a wood furnace that weighed a **** ton plus the crown boiler that weighed a crap ton lol.
    Dec 2010
    Toronto
    Thats one big low loss header......
    May 2012
    Upper Michigan
    It's your boilers best friend!
    Dec 2010
    Toronto
    I hope it is well insulated. Otherwise it is a big radiator.
    May 2012
    Upper Michigan
    Quote Originally Posted by SolarMike View Post
    It's made for this application, spray foam lined, it's basically Thermo mass.
    Jul 2009
    Columbia, MD
    what does the low header do?
    is it for space restrictions?
    May 2012
    Upper Michigan
    It is to prevent short cycling, my boss can get carried away with these things, I could see a 399 firing into a bathroom zone or something but this is maybe overkill lol. The boiler heats the 30 gallons of water and the system cycles on that for a while.
    Jul 2009
    Columbia, MD
    isnt that a modulating boiler?
    if it is, doesn't having the head kind of defeat the purpose?
    May 2012
    Upper Michigan
    It usually works great with non modulating boilers that are zoned off. It is supposed to have a well style aquastat that the boiler just maintains a set temp with. The secondary side runs on and off until the temp drops far enuf for the boiler to fire again.
    May 2012
    Upper Michigan
    Quote Originally Posted by gravity View Post
    It is but does not modulate down far enuf for smallest zone so technically would short cycle, like I said its over kill.
    Jul 2009
    Columbia, MD
    gotcha...pretty cool.
    does that also serve as DHW? or strictly a holding tank for the zones?
